更新時間 2023-07-24 00:54:03 UTC
瀏覽: 8617   回覆: 1
misterhoff
更新時間 2023-07-25 03:11:25 UTC
瀏覽: 7803   回覆: 0
Feature request update
更新時間 2023-07-25 06:11:19 UTC
瀏覽: 8424   回覆: 1
Netro - Stopped Working and won’t power up
John Loethen
更新時間 2023-07-25 14:04:38 UTC
Been a Netro customer for a while and pretty handy. I have three different Netro controllers and my oldest one just stopped working and won’t power up… I have verified the power at the outlet and have changed out the power supply with another 24v power supply that I know works. Still the controller will not power up.
Let me know if anyone else has suggestions.
John in Lincoln, NE
瀏覽: 8005   回覆: 1
Netro Sprite 6 valve won’t stop
Alberto Casu
更新時間 2023-07-29 19:25:45 UTC
I just replaced my sprinkler controller with a new Netro Sprite 6.
Using both a programmed or a manual start, all valves don’t stop unless I remove power to the Sprite.
During a program, where I planned the zones to run sequentially, the zones activate one after the other without stopping and causing the zones to loose pressure and be unable to complete.
On the FAQ, it says to remove power to stop the zone, which actually stop all the watering, but this it totally unusable to me.
I am using the European version with the provided power supplier. I am based in Italy.
Can you please help?
瀏覽: 8583   回覆: 2
Netro phone app won't open
Christopher Scarborough
更新時間 2023-07-30 23:32:37 UTC
瀏覽: 7912   回覆: 1
Tim Quach
更新時間 2023-08-01 08:02:49 UTC
瀏覽: 7904   回覆: 1
Atif Siddiqui
更新時間 2023-08-02 04:51:58 UTC
瀏覽: 7899   回覆: 1
Using Bootlace ferrules.
Bob Howard
更新時間 2023-08-03 06:36:09 UTC
I'd like to use bootlace ferrules for all the wiring to the sprite as shown in your installation video (power connection). I'm using 0.5mm² x 7 core cable and 0.5mm² bootlaces and the unit won't grip them. I've tried other sizes with the same result. What size ferrule is required?
瀏覽: 10533   回覆: 1
Date format
Bob Howard
更新時間 2023-08-03 23:27:42 UTC
瀏覽: 8565   回覆: 1
David H
更新時間 2023-08-04 17:15:09 UTC
瀏覽: 8099   回覆: 1
App show’s pending message
Greg Jones
更新時間 2023-08-07 18:46:13 UTC
瀏覽: 8263   回覆: 1
Drew M
更新時間 2023-08-08 17:48:40 UTC
瀏覽: 7791   回覆: 1
We had 4 inches of rain
更新時間 2023-08-09 03:08:18 UTC
瀏覽: 8440   回覆: 2
Cambio wifi
jmgrau
更新時間 2023-08-09 15:10:03 UTC
Espero su ayuda.
瀏覽: 7812   回覆: 1
App is not installing
Martin Trevino
更新時間 2023-08-09 16:40:50 UTC
瀏覽: 7901   回覆: 1
Louise Brinkman
更新時間 2023-08-10 05:52:23 UTC
瀏覽: 8472   回覆: 1
Spark and Sensors
C He
更新時間 2023-08-10 06:45:57 UTC
Hi all,
Thanks for support!
瀏覽: 8243   回覆: 1
Calendar View
更新時間 2023-08-10 11:23:26 UTC
Netro Support Team,
Houston, Texas
瀏覽: 8304   回覆: 1
technic support
Isabel Santillan
更新時間 2023-08-11 07:07:33 UTC
瀏覽: 7731   回覆: 1
