Franck FONTANEL
更新時間 2025-07-18 19:49:49 UTC
I don’t know why ?
瀏覽: 7266   回覆: 1
Pause
Tamgar chan
更新時間 2025-07-19 10:59:15 UTC
瀏覽: 7569   回覆: 1
Whisperer low battery alert
Jesus Sanguinetti
更新時間 2025-07-19 15:24:34 UTC
瀏覽: 7628   回覆: 1
Stefano
更新時間 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
瀏覽: 7736   回覆: 1
Change zone order
Matt Ward
更新時間 2025-07-22 00:43:18 UTC
瀏覽: 7917   回覆: 1
Andrew Woods
更新時間 2025-07-22 19:30:55 UTC
瀏覽: 5132   回覆: 1
Interoperability with Alexa, Homey, any other smart home platform?
arnaud@brucy.org
更新時間 2025-08-22 19:03:11 UTC
Is there any interoperability/integration existing or planned with home automation/smart home platforms?
Integration with Homey Pro would be great, being able to fetch the watering status for each zone, start a manual watering, or send some external triggers (humidity, rain water tank level, etc.)
Thank you !
Arnaud
瀏覽: 6946   回覆: 2
Password
Ignacio Sánchez
更新時間 2025-09-26 11:38:52 UTC
瀏覽: 5090   回覆: 1
Whisperer installation
Davide Chelo
更新時間 2025-09-26 11:38:17 UTC
Hi, I just bought the whisperer 2 and would like to have it as only sensor for the entire garden, however is allowed to have maximum 3 zones for sensor. Is there a way to link all the zones to it? I have 7 zones.
瀏覽: 4975   回覆: 1
I want to change wifi network my Netro controller is connected too.
loro
更新時間 2025-09-23 21:27:44 UTC
How do I change the wifi network my Netro controller is connected too? I cannot proceed beyond step 2 from the instructions on the app. I get the message "Please connect to Wi-fi network "Netro_IRC_xxx."  However, the app shows that I am already connected!!
瀏覽: 5496   回覆: 1
Info function
Giuseppe
更新時間 2025-09-20 09:48:50 UTC
瀏覽: 5606   回覆: 1
Program change Day
Tiziano Pacella
更新時間 2025-09-17 19:04:30 UTC
Someone can help me?I need change the day for one program exists...what is the procedure? Thak you
瀏覽: 5529   回覆: 1
Rainbird esp me series
Magnus Swenson
更新時間 2025-09-15 14:38:33 UTC
Can I use the Netro Spark 16 if I use the Rainbird ESP Me? I have 15 active zones.
瀏覽: 5815   回覆: 1
Time
Silvano Scotto
更新時間 2025-09-10 23:18:59 UTC
瀏覽: 6341   回覆: 1
Centralina non funziona
gsciurba
更新時間 2025-09-09 19:23:32 UTC
Buongiorno,
  • la tensione in uscita è sempre di circa 11 V AC su tutte le uscite;
  • la centralina è stata utilizzata pochissimo, solo con le zone master e 1–2;
  • non sono presenti segni visibili di bruciatura o danni hardware.
Grazie per l’attenzione.
Cordiali saluti,
Giuseppe Sciurba
瀏覽: 6297   回覆: 1
Netro spark no work
Fernando Bravo Calatayud
更新時間 2025-09-04 08:25:22 UTC
I've had a Netro Spark 8 working without any problems since last year, but a few days ago it disconnected from the Wi-Fi and stopped working. I tried the reset button as indicated in the instructions, but there's no way to reconnect it. What else can I do? Thank you very much
瀏覽: 6750   回覆: 1
Francesco Gritti
更新時間 2025-08-29 16:39:06 UTC
瀏覽: 7015   回覆: 1
更新時間 2025-08-24 22:55:28 UTC
瀏覽: 7256   回覆: 1
Non riesco a connettere metro spring con metro wisperer
Fabio Doc
更新時間 2025-08-23 07:43:08 UTC
瀏覽: 7253   回覆: 1
Interpretation of soil moisture readings by Whisperer
Missy Bartell
更新時間 2025-07-26 12:13:30 UTC
I have two Whisperers that I move around to various parts of my graden to get comparative readings of sunlight and soil moisture.  I really do not know how to interpret the moisture readings which generally range from 50% to 98% but can be as low as 30%.  Soil type varies from a clayey loam to heavy clay.   How do I know when watering is required?  Does the meter measure the capillary water?  The adhered water?  The percentage of voids filled with water?  How does Netro calculate the percentage of water and what do the readings mean?
瀏覽: 5471   回覆: 1
