Zone flexibility
Mike R
更新時間 2025-10-29 01:20:50 UTC
I have a hill that was terraced and replanted. I was told to run the circuit twice a day for 15 minutes for a month. Drip lines. Seems like my system doesn’t have that flexibility. Am i correct?
瀏覽: 4294   回覆: 1
API broken?
Tortfeaser
更新時間 2025-11-21 04:58:13 UTC
Hi, I can get my Netro controller info using:
curl -v https://api.netrohome.com/npa/v2/info.json?key=MYAPIKEY
(where MYAPIKEY is a key from the user account page)
but when I try to update soil moisture data with:
curl -X POST -H "Accept: application/json" -H 'Content-Type:application/json' -d '{"key":"MYAPIKEY","moisture":100}' "https://api.netrohome.com/npa/v2/set_moisture.json"
I get an error about an invalid key:
{"status":"ERROR","meta":{"time":"2025-11-21T04:54:56","tid":"1763700896_KpmY","version":"2.0","token_limit":0,"token_remaining":0,"last_active":"2025-11-21T04:54:56","token_reset":"2025-11-22T00:00:00"},"errors":[{"code":1,"message":"Invalid key: ","params":{}}]}
What's going on?
瀏覽: 16263   回覆: 1
Cannot add pixie z1
John R
更新時間 2025-12-09 02:23:46 UTC
I cannot add my pixie z1 to the app because pixie z1 is not shown as an option. I have the hub connected.
瀏覽: 4059   回覆: 1
Watering on wrong day
keller3987
更新時間 2025-12-09 15:39:44 UTC
I have programmed my Netro to skip Tuesday’s but the controller waters anyway. How do I stop this?
瀏覽: 3897   回覆: 1
The average temperature for a day is insufficient to calculate correct watering.
Richard
更新時間 2025-12-17 07:17:57 UTC
When I have Whisperers, the system appears to calculate the average over the day about 4 degrees higher than for zones without Whisperers.
It seems that, even though the weather data is available throughout the day, that zones without sensors only use the forecast high and low.
This is insufficient to correctly adjust for the amount of watering required.
For example, today is 7 degrees C up to 36.
Whisperer zones average the temp at 26C while non-Whisperer zone calculate the average at 22C.
On these extremely hot days, the non-whisperer zones are under-watering much more than the Whisperer zones.
Also note that even the zones with Whisperers always under-water and needs custom programs or manual intervention.
This finally explains to me why zones are always under-watered.
Can the system please use multiple day readings for non-Whisperer zones and PLEASE provide more watering?
瀏覽: 3913   回覆: 2
Eric Jonsson
更新時間 2026-01-08 12:02:58 UTC
瀏覽: 3889   回覆: 1
Shane V
更新時間 2026-01-19 04:54:45 UTC
瀏覽: 3734   回覆: 1
Old whisperer
更新時間 2026-01-20 10:38:33 UTC
Seems a communication problem
瀏覽: 3615   回覆: 1
Tuan Phan
更新時間 2026-01-25 18:28:34 UTC
瀏覽: 3497   回覆: 1
Will
更新時間 2026-01-27 03:13:26 UTC
瀏覽: 3672   回覆: 1
cpline
更新時間 2026-02-02 17:04:38 UTC
瀏覽: 3664   回覆: 1
Notification
Alexis Demosthenous
更新時間 2026-02-05 19:28:19 UTC
瀏覽: 3711   回覆: 1
Will
更新時間 2026-03-17 21:54:57 UTC
瀏覽: 4366   回覆: 3
Sensor to zone
Mark Zeck
更新時間 2026-02-05 23:17:03 UTC
How do I connect my sensors to zones? I have the latest.
瀏覽: 3737   回覆: 1
Feature Request
John Sirois
更新時間 2026-02-10 05:56:14 UTC
John
瀏覽: 3544   回覆: 1
Supported Hardware
Colin Brierley
更新時間 2026-02-12 06:13:48 UTC
瀏覽: 4022   回覆: 1
Support email- No reply
更新時間 2026-02-21 16:06:19 UTC
瀏覽: 3828   回覆: 2
RKR Home
更新時間 2026-03-03 03:32:35 UTC
瀏覽: 3649   回覆: 1
programs - reordering
Lee Hill
更新時間 2026-05-08 06:40:14 UTC
瀏覽: 2615   回覆: 1
Notifications sur Android
Cyrille ROBINET
更新時間 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
瀏覽: 2677   回覆: 1
