Anne M
更新時間 2026-06-10 22:39:31 UTC
For test purposes, I have my Whisperer 2 in a terra cotta flowerpot that is very dry.  It always reads that the moisture is very high.  I have a Pixie at the house faucet.  I reset the Whisperer and it did not help.  What's wrong?
瀏覽: 2348   回覆: 1
Cannot connect to my WiFi
更新時間 2026-06-10 02:59:45 UTC
Tried several times following with the instructions. And failed!? And my system was operational and my App was disabled for no apparent reasons!?
瀏覽: 2281   回覆: 2
How do I save my password
Ruth Wengert
更新時間 2026-06-09 16:33:16 UTC
I doubt if someone’s gonna break in and change my sprinkler time how in the hell do I save my password to this thing? I don’t wanna have to remember to put it in every time I want to change my sprinklers.
瀏覽: 2478   回覆: 1
Massmo Tommasi
更新時間 2026-06-06 13:21:26 UTC
grazie
瀏覽: 2230   回覆: 1
Rain forecast
Riccardo!!
更新時間 2026-05-31 15:34:34 UTC
Hi, I have a Spark controller. Where can I find in the app the rainfall forecast for next days?
In the home page I can see only humidity, temperature and wind but not rain in mm.
Riccardo
瀏覽: 2346   回覆: 1
wunderground
Nino Guzzo
更新時間 2026-05-28 17:35:15 UTC
I can't register my weather station ID in the Netro app. Can anyone help me? Thanks.
瀏覽: 2595   回覆: 1
sprite not using correct weather data
Douglas Peale
更新時間 2026-05-26 06:47:02 UTC
I have a home weather station that feeds data to https://www.wunderground.com/dashboard/pws/KCASANJO507?cm_ven=localwx_pwsdash
I have my sprite pointed at my specific weather station on wundergound.com. Today, my sprite claims I had 0.02" of rain, but my weather station detected none, and wunderground.com says I had no rain.
I have been noticing for a while that Netro was showing different rain data from what my weather station recorded, Netro usually records more rain than I actually got. I suspect this may be why my oranges are always under sized.
Somehow Netro is getting the wrong infromation from wunderground.com. Is there any way to fix this?
瀏覽: 2461   回覆: 1
Irrigation
Antonio Cordon Rodriguez
更新時間 2026-05-21 19:28:42 UTC
瀏覽: 3997   回覆: 2
Greenhouse zone
Ivan G
更新時間 2026-05-20 08:59:47 UTC
瀏覽: 3922   回覆: 1
Change Wi-Fi connection
Ruth Wengert
更新時間 2026-05-20 03:19:34 UTC
I have changed the name of my Wi-Fi. I need to change my Wi-Fi connection to its new name I have a new Wi-Fi in your hub will not work because it can’t download a new Wi-Fi for some damn reason
瀏覽: 2636   回覆: 2
Ruth Wengert
更新時間 2026-05-20 03:19:27 UTC
瀏覽: 2489   回覆: 0
Ruth Wengert
更新時間 2026-05-20 03:18:14 UTC
瀏覽: 2440   回覆: 1
Changing WiFi Network post original installation
deleted_20260518221841_george
更新時間 2026-05-18 14:03:27 UTC
Hi- been using your sprinkler controller for several years and have recently added a new WiFi network.
I'm following the instructions how to switch the Netro controller to a new WiFi network. After resetting the controller, it change my iphone WiFi network over to Netro-XXX (which tells me I have no internet access).
When I return to the Netro app and click 'Next', it just keeps instructing me to connect to Netro-XXX first.
The Netro controller continues to blink despite unplugging it so stuck in limbo now.
瀏覽: 2501   回覆: 2
Tuan Phan
更新時間 2026-01-25 18:28:34 UTC
瀏覽: 3497   回覆: 1
Notification
Alexis Demosthenous
更新時間 2026-02-05 19:28:19 UTC
瀏覽: 3711   回覆: 1
cpline
更新時間 2026-02-02 17:04:38 UTC
瀏覽: 3664   回覆: 1
Will
更新時間 2026-01-27 03:13:26 UTC
瀏覽: 3672   回覆: 1
Will
更新時間 2026-03-17 21:54:57 UTC
瀏覽: 4366   回覆: 3
Old whisperer
更新時間 2026-01-20 10:38:33 UTC
Seems a communication problem
瀏覽: 3615   回覆: 1
Shane V
更新時間 2026-01-19 04:54:45 UTC
瀏覽: 3734   回覆: 1
