Tony Pellegrino
更新時間 2021-04-13 19:14:36 UTC
瀏覽: 8180   回覆: 1
Fabio Pellizzoni
更新時間 2021-04-13 20:10:43 UTC
Do you have any idea why ?
瀏覽: 6898   回覆: 1
How to Set Schedule?
tonycurry
更新時間 2021-04-14 02:13:12 UTC
瀏覽: 6878   回覆: 1
Manual start on demand
Krzysztof Wiater
更新時間 2021-04-14 03:34:58 UTC
I just got unit garden hose pixie unit. I am looking for a manual watering on demand button. I want to be able to turn it on and off an needed. Right now i see I have to wait 1 hr or so to turn it on. Am I missing something here? Please help. Thanks in advance.
瀏覽: 8402   回覆: 1
Time zone not supported
Havre de Grace
更新時間 2021-04-15 08:11:30 UTC
I keep getting this error when I try to put my address in Jersey, Channel Islands.
瀏覽: 6486   回覆: 1
How to delete a device
Carles
更新時間 2021-04-16 12:33:31 UTC
瀏覽: 7113   回覆: 1
Multiple Pixies?
J Forrest
更新時間 2021-04-17 03:33:18 UTC
瀏覽: 6771   回覆: 1
Whisperer sensor soil type
Aki Lan
更新時間 2021-04-17 13:47:25 UTC
Is whisperer sensor able to know your soil type due to drain capacity?
瀏覽: 8190   回覆: 1
dougbrandes
更新時間 2021-04-19 10:06:30 UTC
瀏覽: 6759   回覆: 1
Email address
Troy pascoe st
更新時間 2021-04-19 11:01:30 UTC
瀏覽: 6712   回覆: 1
Michael Sheahan
更新時間 2021-04-19 21:19:54 UTC
瀏覽: 8077   回覆: 1
Mitch Green
更新時間 2021-04-20 00:44:59 UTC
瀏覽: 7634   回覆: 1
Jason
更新時間 2021-04-20 21:49:32 UTC
瀏覽: 6498   回覆: 1
Weather data
Vardhan Rajkumar
更新時間 2021-04-21 18:03:34 UTC
Vardhan
瀏覽: 8706   回覆: 1
Zones
dougbrandes
更新時間 2021-04-22 12:34:57 UTC
I only have 2 zones.  1st zone is programmed for only 2 days per week while the 2nd zone is programmed everyday and at a different time then the first zone.  However on the 2 days the first zone comes on, the second zone does not despite be programmed to.  As mentioned the on times are completely different.
瀏覽: 6589   回覆: 1
Trigger a single zone based on zwave switch
Moe E
更新時間 2021-04-22 14:54:46 UTC
My pools water fill line is connected as a zone on my sprinkler system. I would like to trigger turning on and off a zone based on a zwave switch status. Can this be done, or should I return my netro for a different system? It looks like netro does not have api access, and IFTTT is extremely limited. Thanks
瀏覽: 6738   回覆: 1
LAWN
更新時間 2021-04-23 23:08:09 UTC
Set up wifi
Neti URC - 87B (ok saved)
home netwok connected.
瀏覽: 6809   回覆: 1
Open tel zones atbthe same time
ivan hernandez
更新時間 2021-04-25 11:58:25 UTC
I have to activate two zones at the same time but i dont know how to do It.
瀏覽: 8043   回覆: 1
Can not connect to wifi
Andrei Stancovici
更新時間 2021-04-25 18:30:25 UTC
Hello. I have restarted my netro 16 after winter. First it connected ok and after a power lose i stopped connecting to wifi. I have tried everything. The light is solid as if is connected. Plese help. Thank you
瀏覽: 6507   回覆: 1
Netro app discover tab
Zee D
更新時間 2021-04-25 20:52:09 UTC
瀏覽: 6623   回覆: 1
