Where do I have to install the whisper sensor?
Paolo1968
更新時間 2021-05-11 09:46:31 UTC
I have recently bought  a whisper sensor to complement my Netro watering system. I have a watering system in the garden, where Can I install the whisper in order to avoid it will be wet all days by the watering system? Do I have to put it outside of the garden? Thanks. Paul
瀏覽: 9357   回覆: 2
Whisperer stop working
Gianluca De Virgilio
更新時間 2021-05-11 15:34:15 UTC
Ideas?
瀏覽: 7470   回覆: 1
Smart water regulation
Albert Heinold
更新時間 2021-05-13 09:40:49 UTC
Thanks for any help.
瀏覽: 6994   回覆: 1
Whisper Pairing
Sang Peiris
更新時間 2021-05-13 12:11:59 UTC
Hello-  I have two new whisper devices. Both will not go into pairing mode.  Press power button six times and the light just blinks red on and quickly off. Press three times and same thing.
How do I get the whisper into pairing mode?
瀏覽: 8773   回覆: 1
Rainfall from weather station
更新時間 2021-05-14 16:50:13 UTC
瀏覽: 8747   回覆: 1
John Lillistone
更新時間 2021-05-15 09:23:08 UTC
Any ideas anyone?
瀏覽: 8426   回覆: 2
Watarering modes
更新時間 2021-05-16 07:44:57 UTC
Hi there
瀏覽: 9211   回覆: 2
Seed watering
Adrian Azzopardi
更新時間 2021-05-16 10:18:05 UTC
瀏覽: 7248   回覆: 1
Turning off wayer
更新時間 2021-05-16 21:29:12 UTC
瀏覽: 7877   回覆: 2
Programs Setup
fernando colon
更新時間 2021-05-18 04:44:56 UTC
I have 5 zones programmed daily in 15/20/35 mins intervals however when I goto the home screen I see them all in 15mins intervals... Seems as the home screen bypass' the current daily programmed schedule.  How do I have my programs run as intended 15/20/35 .ins intervals vs the 15mins it self imposed?
瀏覽: 9082   回覆: 1
Whisperer connexion
更新時間 2021-05-19 14:52:55 UTC
瀏覽: 8383   回覆: 2
amagalla
更新時間 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
瀏覽: 8290   回覆: 2
bad wireless?
amagalla
更新時間 2021-05-19 16:50:44 UTC
Tony
瀏覽: 7453   回覆: 1
Netro Pixie Timer
claudinne
更新時間 2021-05-20 17:09:36 UTC
瀏覽: 8577   回覆: 1
Mitch Green
更新時間 2021-05-20 22:11:37 UTC
瀏覽: 8930   回覆: 1
Learning
John Conley
更新時間 2021-05-21 12:05:43 UTC
瀏覽: 8354   回覆: 1
Sensor usage
Ilya Lifshits
更新時間 2021-05-22 08:17:29 UTC
Hi ,
Ilya
瀏覽: 8510   回覆: 1
Brad Grizzly
更新時間 2021-05-23 03:42:20 UTC
瀏覽: 6906   回覆: 1
Connect one whisperer to two pixies
jmkluft
更新時間 2021-05-24 14:14:03 UTC
For the moment, I have one whisperer connected to one pixie, and everything is working fine.
I have a question though, if I would add another pixie to control another watering zone, can I connect the same whisperer to that second pixie?
In other words, can I connect one whisperer to two pixies?
Thx,
JM
瀏覽: 8689   回覆: 1
banaszar
更新時間 2021-05-25 17:23:58 UTC
瀏覽: 6994   回覆: 2
