whisperer + smartzone
更新時間 2021-06-14 20:59:45 UTC
瀏覽: 8809   回覆: 1
Backup
klzig
更新時間 2021-06-15 14:09:28 UTC
Best I can tell from the cursory technical specs is that for the Sprite the backup for a custom (not smart) watering schedule is in the cloud and for the Spark the backup is stored on-device in nonvolatile memory.  Is this correct?
瀏覽: 8180   回覆: 1
klzig
更新時間 2021-06-15 14:16:19 UTC
瀏覽: 7895   回覆: 1
Watering adjustment settings
Lyndon Whyatt
更新時間 2021-06-15 16:55:38 UTC
瀏覽: 7241   回覆: 2
更新時間 2021-06-16 14:03:50 UTC
瀏覽: 7384   回覆: 1
Jen Wells
更新時間 2021-06-17 00:36:39 UTC
瀏覽: 7070   回覆: 1
System stuck on watering
Haris Eliades
更新時間 2021-06-17 05:07:11 UTC
瀏覽: 6996   回覆: 2
Network error
Al Piscopo
更新時間 2021-06-17 10:27:03 UTC
瀏覽: 6417   回覆: 1
Smart zone predictions?
Sid Smith
更新時間 2021-06-17 12:12:33 UTC
瀏覽: 6970   回覆: 1
How to turn off Smart control
Riccardo Secco
更新時間 2021-06-17 19:47:41 UTC
瀏覽: 6766   回覆: 1
aceking
更新時間 2021-06-18 12:41:57 UTC
瀏覽: 6611   回覆: 2
Google home
Sasha Obradovic
更新時間 2021-06-18 13:56:27 UTC
瀏覽: 7313   回覆: 2
Smart watering
Scott Schoenfeld
更新時間 2021-06-19 18:25:03 UTC
瀏覽: 7001   回覆: 2
BOB COOPER
更新時間 2021-06-20 16:40:50 UTC
瀏覽: 11414   回覆: 1
Programs that ignore sensors?
Jacques
更新時間 2021-06-20 19:10:17 UTC
瀏覽: 8389   回覆: 1
Richtiger niederschlag
Gregor Schuller
更新時間 2021-06-21 09:41:39 UTC
Hallo,
Zurzeit ist nur 1 mm möglich
瀏覽: 6955   回覆: 1
Ken Laberteaux
更新時間 2021-06-22 04:16:23 UTC
瀏覽: 8627   回覆: 2
Still irigates on rain days
Anyhony Harwood
更新時間 2021-06-24 11:30:50 UTC
瀏覽: 8026   回覆: 1
Reset whisper sensor
Yuriy Andamasov
更新時間 2021-06-24 18:06:20 UTC
Like hard reset
Not like that
瀏覽: 8473   回覆: 1
Sensor not reading moisture
8
更新時間 2021-06-24 19:37:55 UTC
I have three whisper sensors,  all of them  but one is reporting moisture levels.  Temperature and sunlight are correct, but moisture is 0%.. I have reset the self learning, Did a hard reboot, and  Reattached the sensor to a different wireless network.  What else can be done?
瀏覽: 8004   回覆: 1
