Jcraft200
更新時間 2021-07-18 02:44:57 UTC
I get to set 3 set up wifi
TIA
瀏覽: 7143   回覆: 4
Internet down
更新時間 2021-07-18 11:38:25 UTC
瀏覽: 8593   回覆: 2
Addiel Isaac Moldes
更新時間 2021-07-18 12:42:37 UTC
It was or wasn't included?
瀏覽: 7087   回覆: 1
Default view on startup
Addiel Isaac Moldes
更新時間 2021-07-18 12:45:53 UTC
瀏覽: 7050   回覆: 1
wwhitfill
更新時間 2021-07-18 13:52:07 UTC
瀏覽: 8174   回覆: 2
Barry Litinsky
更新時間 2021-07-18 23:12:56 UTC
瀏覽: 6452   回覆: 1
Pixie and Whisperer
Nick Thoman
更新時間 2021-07-19 17:46:37 UTC
瀏覽: 7211   回覆: 1
Ramón Rivero
更新時間 2021-07-20 08:32:53 UTC
瀏覽: 6916   回覆: 1
Not all zones are executing
Brian Brun
更新時間 2021-07-20 14:19:47 UTC
瀏覽: 7460   回覆: 1
BaiPhillips
更新時間 2021-07-20 20:42:15 UTC
瀏覽: 6973   回覆: 2
New lawn setting
更新時間 2021-07-21 01:54:26 UTC
瀏覽: 7496   回覆: 1
Netro Pixie with Google Home
fauxserious
更新時間 2021-07-21 19:50:41 UTC
What is the issue?
瀏覽: 7298   回覆: 1
Two electro valves activated at same time
Francesc Rodríguez
更新時間 2021-07-21 20:07:01 UTC
Why is not possible two valves operating at the same time if the pump can be operate correctly?
瀏覽: 8805   回覆: 1
Connect to a network
James Yates
更新時間 2021-07-22 21:08:14 UTC
瀏覽: 6292   回覆: 1
Keep Online
bechard
更新時間 2021-07-24 11:09:25 UTC
瀏覽: 7559   回覆: 0
Strange Whisperer Acrtivity
更新時間 2021-07-24 17:00:16 UTC
瀏覽: 11091   回覆: 5
Eric
更新時間 2021-07-25 05:56:52 UTC
瀏覽: 6375   回覆: 1
Installing New Netro-6
Debby Plenert
更新時間 2021-07-25 14:37:04 UTC
I removed an older controller and replicated the wiring when installing the new Netro.  Everything appears to be correct?  However, when watering is activated, the valves will fill up and vibrate or what not with water rushing internally.  But the sprinkler heads don’t pop up and no water comes out.  Any help here would be greatly appreciated.  Thanks!
瀏覽: 8653   回覆: 1
Rain sensor
更新時間 2021-07-26 12:13:34 UTC
瀏覽: 8790   回覆: 1
更新時間 2021-07-26 16:02:28 UTC
瀏覽: 8801   回覆: 2
