Haris Eliades
更新時間 2020-11-25 06:25:20 UTC
Haris
瀏覽: 7488   回覆: 3
Master valve timing
joeac
更新時間 2020-12-04 05:38:31 UTC
Product: Sprite
Joe
瀏覽: 8694   回覆: 1
How to make Netro sensor repair
Bowie Xu
更新時間 2020-12-06 21:04:42 UTC
My sensor doesn’t blink white led. When I presses the power button, it shows solid white for a while and then green color and red and goes off. The instructions make me confused. I tried to press the power button for 6 times. What does restart 3 times means? My sensor never goes to blinking white color.
瀏覽: 9351   回覆: 1
Battery dead
Arthur
更新時間 2020-12-07 22:00:27 UTC
瀏覽: 7470   回覆: 1
Moisture uncorrect
Andrea Pieri
更新時間 2020-12-08 05:43:25 UTC
瀏覽: 11548   回覆: 1
Automatic switch to 12 hour reporting for sensors
Julian Hansen
更新時間 2020-12-10 12:30:21 UTC
Hi I have 6 senors that have all worked perfectly for 3 months unattended. A month ago I noticed 1of them only had 5% charge so I switched it to 12 hour reporting and it is now on 38%. Today another sensor has gone to 0% charge and stopped reporting. It would be great if you could be set it automatically switch at say 30% charge. It will be 3 months before I am back to the house so I hope the sensor can recover. Thanks for a fantastic product.
瀏覽: 7753   回覆: 1
Sensor Temperature Reporting
Nasser Ahmed
更新時間 2020-12-14 02:12:42 UTC
One of my sensors is reporting strange temperature numbers. Any ideas on how to fix this. I tried a reboot and a reset (remove and add again).
瀏覽: 7271   回覆: 1
Pixie Valve Issue
Alec Simonson
更新時間 2020-12-15 05:48:10 UTC
Alec
瀏覽: 7930   回覆: 2
Roman Stanek
更新時間 2020-12-27 18:34:40 UTC
瀏覽: 6968   回覆: 1
Metro France cloud down?
Julian Hansen
更新時間 2020-12-29 01:07:40 UTC
瀏覽: 7757   回覆: 1
Moisture and light range
Don Lewandowski
更新時間 2020-12-31 21:46:19 UTC
瀏覽: 11725   回覆: 1
Darren Cassar
更新時間 2021-01-05 11:03:18 UTC
Darren
瀏覽: 7186   回覆: 1
MAC address
John Conley
更新時間 2021-01-07 15:26:26 UTC
瀏覽: 7159   回覆: 1
Technical question
Enrique Campos Sanchez
更新時間 2021-01-14 20:36:25 UTC
Hi team.
I would like to know what is the maximun wire longitude that support by zone the Netro Driver using 24 VAC power supply.
Thank´s.
瀏覽: 8754   回覆: 1
Geron R
更新時間 2021-01-19 23:06:52 UTC
Please advise
瀏覽: 7498   回覆: 1
Cancel
Awilda Betancourt
更新時間 2021-01-24 13:09:23 UTC
瀏覽: 7104   回覆: 1
Date Format
Brian Keenan
更新時間 2021-01-29 09:00:07 UTC
瀏覽: 6994   回覆: 1
Smart Watering Algorithm
更新時間 2021-02-09 13:52:56 UTC
瀏覽: 7799   回覆: 1
Turning off
Rony Z
更新時間 2021-02-15 13:58:39 UTC
瀏覽: 7320   回覆: 1
AMC
更新時間 2021-02-18 13:04:06 UTC
hello,
¿How Can I solve this issue?
APP version 2.5.3
瀏覽: 8960   回覆: 3
