Temporarily stop all watering
Williams
更新時間 2020-09-07 15:57:32 UTC
How do I temporarily stop all watering without losing the programming?
瀏覽: 8573   回覆: 1
Netro and Google home
Cesar
更新時間 2020-09-08 08:26:17 UTC
HI
Could you please help
瀏覽: 6799   回覆: 1
Shut down for winter
Chad Fuller
更新時間 2020-09-10 02:01:10 UTC
瀏覽: 7892   回覆: 1
Rain Snow Delay
R H
更新時間 2020-09-10 03:35:37 UTC
瀏覽: 7222   回覆: 1
IFTTT - Watering Schedule
更新時間 2020-09-10 05:56:28 UTC
Thanks in advance,
瀏覽: 7660   回覆: 1
Way to add weather stations
Curt Lizzi
更新時間 2020-09-12 01:16:55 UTC
I find the Weather apps to be very inaccurate with respect to rainfall at my home. Is there a way to add a near by weather station for better accuracy?
瀏覽: 7565   回覆: 1
Potted plant on terrace
Andrea Zorgniotti
更新時間 2020-09-14 07:46:03 UTC
Hi I Have a big terrace with many plants divided in 3 zone controlled by Netro. To use the smart watering and have an acceptable time/frequence for watering (6 min every 2.5 days) I have to set user and from 80% to 85% umidity. If I set frequent or extra water the estimated frequency is 4/5 days. Considering in summer my setting seems nor giving enough water to plants what kind of setting do you suggest to increase the frequency (change msq, kind of sprinkle or whatever).
Thanks in advance for answer
瀏覽: 7481   回覆: 1
loose connection on install
Lawrence Jones
更新時間 2020-09-15 22:49:22 UTC
The unit is working good, yeah!  The way the wires get tab/push for contact is really cheap.  The "spring" of the contact is very , very loose.
Move the wire at all and no contact.  Then trouble shooting to find where trouble is.  Not a good design. Need a much more firm grip on the bare wire. something else or just poor quality?
瀏覽: 8671   回覆: 1
Start time change
Franco Storato
更新時間 2020-09-16 06:00:59 UTC
Thank you in advance,
Franco
瀏覽: 6849   回覆: 1
Contact
Santiago Errazuriz
更新時間 2020-09-16 14:44:36 UTC
Hello good morning, greetings from Chile. I need to know if I can have a whatsapp or contact email.
瀏覽: 8337   回覆: 1
Simple on/off
gmcg1984
更新時間 2020-09-17 01:54:35 UTC
瀏覽: 7047   回覆: 1
Multiple sprinklers in one zone - and is there a Test System ?
Cormac Champion
更新時間 2020-09-19 13:48:55 UTC
Can zones be setup with several sprinklers in the one zone ?  From what I can see from another question, is it correct that you setup the aproximate size of each zone ?  I have several zones with maybe 10 sprinklers in each zone, with sprinklers about 3m apart.
Also, is there any access to a test / simulation system that I can setup my location and see how well it would adapt to weather.  I am planning the installation for southern Spain
Thanks in advance
瀏覽: 7564   回覆: 1
HomeOwner
Isaac Fishman
更新時間 2020-09-21 01:14:55 UTC
瀏覽: 8360   回覆: 1
Controller LED Light
Texas AF
更新時間 2020-09-22 14:01:57 UTC
瀏覽: 7197   回覆: 1
Second house
Dave Hornsey
更新時間 2020-09-29 18:20:51 UTC
I'm in the very fortunate position of having 2 homes - one in the UK and one in Spain. We've just had the garden reworked in the UK and I've been able to install an irrigation system controlled by a single Sprite controller.
I'm very pleased with how this is working - and now want to upgrade the manual irrigation system we have in our Spanish house to a smart system. Can Netrohome / the (Android) app manage 2 different irrigation systems in 2 different locations (with 2 very different climates)?
Many thanks.
瀏覽: 8591   回覆: 1
Atif Khan
更新時間 2020-10-01 14:21:57 UTC
瀏覽: 7011   回覆: 1
OFFLINE
Javier López-Guerrero
更新時間 2020-10-03 08:20:26 UTC
Help!
Javier
瀏覽: 6983   回覆: 2
Switch Off automatically
Carlos Jimenez
更新時間 2020-10-09 20:18:31 UTC
I found two cases,
瀏覽: 7057   回覆: 1
Simone Nolletti
更新時間 2020-10-11 11:46:06 UTC
Buonasera,
瀏覽: 7741   回覆: 1
Questions about Netro app
Luis Aguilar
更新時間 2020-10-11 17:47:55 UTC
瀏覽: 7221   回覆: 1
