更新時間 2020-07-04 13:11:16 UTC
Zone 1-11 minutes each run
Zone 2-11 minutes each run
Zone 3-06 minutes each run
Zone 7-06 minutes each run
瀏覽: 8543   回覆: 1
Brendan Burke
更新時間 2020-07-04 14:38:40 UTC
瀏覽: 7777   回覆: 1
Michael Fortwengler
更新時間 2020-07-04 19:06:14 UTC
瀏覽: 7068   回覆: 1
sw238
更新時間 2020-07-05 15:42:38 UTC
瀏覽: 7232   回覆: 1
Add solenoid valves
thái bình dương
更新時間 2020-07-06 17:01:57 UTC
hi netro
I have 48 solenoid valves and I want to connect 3 valves to 1 zone of the sprite kit, each valve has a capacity of 3w. Thank you
瀏覽: 8526   回覆: 1
Hozelock
Alan George
更新時間 2020-07-06 18:50:08 UTC
瀏覽: 7123   回覆: 1
Battery status
Francis Ramos
更新時間 2020-07-07 15:07:47 UTC
瀏覽: 7044   回覆: 1
Jim Falvey
更新時間 2020-07-07 23:54:23 UTC
瀏覽: 8703   回覆: 1
Andrea Merito
更新時間 2020-07-08 07:15:38 UTC
thank you
Andrea
瀏覽: 7561   回覆: 1
Arthur
更新時間 2020-07-08 16:08:19 UTC
瀏覽: 7147   回覆: 1
JanT
更新時間 2020-07-08 18:44:04 UTC
瀏覽: 8504   回覆: 1
Not enough watering time
Homestead One
更新時間 2020-07-08 20:04:00 UTC
I have 4 zones activated.
Please help.
瀏覽: 7638   回覆: 1
Just stopped working?
Bari Sadler
更新時間 2020-07-10 21:41:47 UTC
瀏覽: 6891   回覆: 1
Time delay
Bruce Vandyke
更新時間 2020-07-11 20:43:26 UTC
瀏覽: 6937   回覆: 1
Scott McKay
更新時間 2020-07-11 21:50:21 UTC
瀏覽: 7026   回覆: 1
Tariq Khan
更新時間 2020-07-11 22:25:30 UTC
瀏覽: 7180   回覆: 1
Offline sratusc
Andrea Del Ben
更新時間 2020-07-12 19:31:12 UTC
瀏覽: 8667   回覆: 1
Does Pixie timer have an integrated water back flow?
Sierra Kiner
更新時間 2020-07-13 17:27:01 UTC
Is water backflow integrated into the Pixie timer or does installation require a separate one?
瀏覽: 9131   回覆: 1
user manual in spanish
Alejandro
更新時間 2020-07-14 10:00:20 UTC
瀏覽: 7478   回覆: 1
Whisperer night light
Arthur
更新時間 2020-07-15 05:45:42 UTC
I have 2 whisperers. Both have the nightlight enabled to auto but only one of them turns it on at night the other never does. Any advice?
瀏覽: 8660   回覆: 2
