Error in watering ?
Davide M.
更新時間 2022-08-29 11:31:56 UTC
Please help me:
  1.  what should I trust ?
APP:
WEB:
瀏覽: 8632   回覆: 1
A Gallo
更新時間 2022-08-29 14:28:38 UTC
瀏覽: 8197   回覆: 1
IFTTT out of sync
更新時間 2022-08-30 07:08:46 UTC
Please advise.
瀏覽: 8853   回覆: 2
Program
Bob Neal
更新時間 2022-08-31 17:11:55 UTC
瀏覽: 6757   回覆: 1
Random sprinklers turn on
Brian Strickler
更新時間 2022-09-01 12:33:12 UTC
瀏覽: 7265   回覆: 2
Help! Pump Relay Question
更新時間 2022-09-01 13:43:25 UTC
My unit has been working great . However, the relay no longer trips when a zone is activated. Am I supposed to have 24v A/C between M and C (on the right side of the panel, not the zone side) when a zone is active? I can trip the relay if I pull it from the Netro. Some sort of voltage output map would be helpful.
I have new grass seed down, so please help soon.
瀏覽: 10019   回覆: 1
How many rain sensors?
Roland Pircher
更新時間 2022-09-01 17:53:32 UTC
瀏覽: 7922   回覆: 1
Two zones running at the same time
Jesse Sanchez
更新時間 2022-09-02 03:52:13 UTC
Anyone running into an issue of having two zones run at the same time when doing a manual run?
瀏覽: 8022   回覆: 1
Karen Thompson
更新時間 2022-09-02 15:15:20 UTC
瀏覽: 8608   回覆: 1
更新時間 2022-09-05 21:41:34 UTC
KVACHEST132
瀏覽: 7472   回覆: 1
更新時間 2022-09-07 05:47:06 UTC
May you check it?
瀏覽: 7535   回覆: 1
更新時間 2022-09-07 21:08:59 UTC
瀏覽: 8578   回覆: 1
更新時間 2022-09-10 12:26:33 UTC
瀏覽: 8701   回覆: 1
Add a manager
Tom Warren
更新時間 2022-09-10 16:36:08 UTC
瀏覽: 8122   回覆: 2
Cannot reset Sprite
punyelroo
更新時間 2022-09-10 22:30:01 UTC
How do I fix this ?
-A
瀏覽: 8430   回覆: 1
quick stop every watering
Lee Hill
更新時間 2022-09-11 20:34:04 UTC
瀏覽: 7167   回覆: 1
Mulch impact on duration
John Wright
更新時間 2022-09-13 12:58:29 UTC
瀏覽: 8204   回覆: 1
Different symbols in the app
Leon Durning
更新時間 2022-09-13 16:05:13 UTC
What does the ! mean?
瀏覽: 8214   回覆: 1
Not watering
jons
更新時間 2022-09-16 09:37:00 UTC
It shows watering, but it is not?
瀏覽: 8043   回覆: 1
Fernando Cantu
更新時間 2022-09-19 03:37:26 UTC
瀏覽: 9148   回覆: 2
