Update Feature
更新時間 2022-08-17 16:09:34 UTC
Alfonso
瀏覽: 8678   回覆: 1
Valeria Dp
更新時間 2022-08-18 10:11:54 UTC
瀏覽: 8011   回覆: 1
How to remove rain delay
Gyanendra Kumar
更新時間 2022-08-18 19:35:45 UTC
瀏覽: 11140   回覆: 1
更新時間 2022-08-19 00:34:04 UTC
瀏覽: 8501   回覆: 1
Why gap in smart schedule?
更新時間 2022-08-19 00:35:41 UTC
瀏覽: 8558   回覆: 1
更新時間 2022-08-19 20:49:40 UTC
Wency,
瀏覽: 7361   回覆: 1
Whisperer too weak
更新時間 2022-08-19 21:10:55 UTC
Hi there
瀏覽: 8650   回覆: 1
Total reset
Azrandy
更新時間 2022-08-20 17:23:56 UTC
How do you do a total reset?
Seamed to be stuck ?
瀏覽: 6671   回覆: 1
更新時間 2022-08-21 09:13:22 UTC
瀏覽: 8493   回覆: 1
Can Pixie measure water flow?
更新時間 2022-08-23 14:09:01 UTC
瀏覽: 8427   回覆: 1
Kasper Huber
更新時間 2022-08-24 13:15:29 UTC
瀏覽: 8049   回覆: 1
Clock on sprite
Rory
更新時間 2022-08-24 19:43:30 UTC
瀏覽: 7919   回覆: 1
texan4ever521
更新時間 2022-08-24 20:24:11 UTC
My settings :
soil type: clay
sprinkler type: rotor head
shade: none or some shade
瀏覽: 8408   回覆: 1
How can add zones
Veronica Slaughter
更新時間 2022-08-25 04:20:46 UTC
瀏覽: 6928   回覆: 1
Suspect a shorted solenoid
rbrodt
更新時間 2022-08-25 16:00:32 UTC
I bought a Netro Spark to replace an existing controller (a Raspberry pi based Open Sprinkler system) which exploded probably due to a shorted solenoid.
I read that the Spark can detect solenoids that are drawing too much current; is it safe to connect the Spark to shorted solenoids without worrying about damage to the controller?
Should I test all the solenoids with an amp meter first just to make sure?
瀏覽: 8935   回覆: 1
rbrodt
更新時間 2022-08-25 16:29:00 UTC
瀏覽: 8243   回覆: 1
Wunderground
Brian Strickler
更新時間 2022-08-25 16:43:35 UTC
How can I get station id
KMTJOLIE28
Added to my controller
瀏覽: 7017   回覆: 1
Soil
Stephen Brewer
更新時間 2022-08-27 12:11:15 UTC
Many thanks in advance
瀏覽: 11219   回覆: 1
Manual watering
Hadeel Hammodat
更新時間 2022-08-29 02:22:09 UTC
瀏覽: 7937   回覆: 1
App locks up
更新時間 2022-08-29 08:39:41 UTC
Please advise.
瀏覽: 8645   回覆: 1
