Green Peas
更新時間 2023-01-01 18:34:14 UTC
瀏覽: 8146   回覆: 2
Home Assistant
Jens Wymeersch
更新時間 2023-01-12 09:25:04 UTC
瀏覽: 9493   回覆: 2
Customized moisture level not triggering watering
Richard
更新時間 2023-01-12 21:29:59 UTC
I have a Sprite with 3 Whisperers, all in the veggie patch.
I have the zones set to customize with a low of 25% and a high of 45% (I find 30 - 35 % moisture about right)
But the zones just won't get watered!
Zone 1 is down to 6% today and has been dropping steadily for days.
I HAVE to manually water, as the day time temperatures are consistently over 30 degrees (today 33, tomorrow 37).
Otherwise the plants will die.
Given there are only two values to enter (low and high). How do I stop the Netro from skipping days and putting the zones in the "Moisture" category??
瀏覽: 9567   回覆: 1
Change Username
Casa Luna
更新時間 2023-01-13 10:08:35 UTC
Is it possible?
Thanks in advance :)
瀏覽: 7477   回覆: 1
Delay on Manual watering
Jim Barnes
更新時間 2023-01-22 01:22:58 UTC
Why is it when I select a manual watering it delays until wake up?
瀏覽: 8051   回覆: 1
Reduce watering time in 1 zone
Ale Levi
更新時間 2023-01-22 19:32:59 UTC
Hi, I'd like to reduce the watering time in 1 zone which gets dumped each time Netro waters. The other zones are ok. Is there a way to do that in the smart mode? Maybe set an offset for that specific zone?
瀏覽: 7588   回覆: 2
andrew58
更新時間 2023-01-25 08:49:48 UTC
瀏覽: 7563   回覆: 1
Jim Barnes
更新時間 2023-01-25 13:36:55 UTC
Please help!!!
瀏覽: 8169   回覆: 2
Whisperer plant sensor
Vincent Coutinho
更新時間 2023-01-26 20:56:14 UTC
How do you find the sensor battery percentage on the netro app.
瀏覽: 8290   回覆: 1
Help
Vũ Trần
更新時間 2023-01-30 07:35:09 UTC
瀏覽: 9691   回覆: 3
Whisperer light
更新時間 2023-02-01 09:56:18 UTC
What should I do ?
瀏覽: 8321   回覆: 1
MEANING OF code E2
balvant patel
更新時間 2023-02-02 16:06:49 UTC
What is E2 means?
Pl. reply ASAP
Patel
瀏覽: 7889   回覆: 1
Vanina Lesko
更新時間 2023-02-03 09:47:24 UTC
瀏覽: 8115   回覆: 1
Smart schedules
Vincent Coutinho
更新時間 2023-02-07 20:51:01 UTC
瀏覽: 8263   回覆: 1
Whispered sola panel deteriorated after 6 months
更新時間 2023-02-08 06:15:54 UTC
After 6 months of whispere’s exposed to sun, the protective layer of screen is started yo be deteriorated, losing the transparency property and protection to UV, meaning is catching up less sun.
Answer from Netro support after several exchanges had not been at the right level, despite that last topic was really well addressed.
“Thanks for your info and it should not affect the normal use of the sensor. Please let us know if you see any further issues during use.“
Check pictures and make your statement, but I am not convince about quality of manufacturing of the whispered elements.
David
瀏覽: 8393   回覆: 1
Set watering days
Mel Culley
更新時間 2023-02-12 02:31:35 UTC
I am struggling to set up the watering days
There isn’t an option for 4 / 3 / 4 rostered days which is are allocation here in Perth Australia
Please advise
TIA 👍
瀏覽: 11009   回覆: 2
Richard
更新時間 2023-02-17 06:29:52 UTC
Hi there.
Cheers.
瀏覽: 8481   回覆: 2
Smart zone manual setup
Vieri Verze
更新時間 2023-02-18 08:31:43 UTC
I do not understand how many millimeters to set. I have microsprinklers of 4lt/h and 2lt/h. I thought to set to 4000ml/h but the max is 100ml/h.
How to calculate? I have a big terrace with 30 plants and various microsprinklers.
Vieri
瀏覽: 8260   回覆: 2
Location Setting
ubo25
更新時間 2023-02-18 10:10:44 UTC
Please advise how I can change the location. I am staying in Windhoek, Namibia.
瀏覽: 7681   回覆: 1
Notifications/Wunderground
Fernando AT
更新時間 2023-02-26 18:00:46 UTC
Hello!
1. How can I enable notifications (when watering, sensor moisture level…)?
2. Cannot set my Wunderground station ISANTA605.
瀏覽: 7838   回覆: 1
