0 Minute Zones?
Stephen Wyatt
更新時間 2023-04-26 12:59:02 UTC
瀏覽: 7452   回覆: 1
How to cancel schedule
Wayne Curdy
更新時間 2023-04-27 01:15:38 UTC
瀏覽: 7577   回覆: 1
Purchasing in the UK
Phil Middleton
更新時間 2023-04-27 21:05:51 UTC
I have purchased Netro Sprite from Amazon. I'm now trying to purchase a couple of Whisperer units. Is there anywhere in the UK as purchasing from the online shop the delivery charge is over $26.
Phil
瀏覽: 8654   回覆: 1
Alexa
Federico Gietz
更新時間 2023-04-30 15:28:52 UTC
瀏覽: 7680   回覆: 1
Pixie connection
Sarroniz
更新時間 2023-05-01 06:20:22 UTC
I already have the Sprite 12 and want to add one or two Pixies.
Do I need the hub for the pixie or the sprite12 acts as hub?
Sergio
瀏覽: 7973   回覆: 1
Suggestion
Tom Carn
更新時間 2023-05-01 17:01:12 UTC
瀏覽: 7539   回覆: 1
Pixie Z1
Jason Willis
更新時間 2023-05-02 14:13:57 UTC
Jason Willis
Jason@wishsystems.biz
瀏覽: 8087   回覆: 1
Michael Cayless
更新時間 2023-05-03 15:45:48 UTC
瀏覽: 8032   回覆: 1
Francesco Zorzetto
更新時間 2023-05-05 23:09:14 UTC
瀏覽: 7880   回覆: 1
Rain delay
David M.
更新時間 2023-05-07 04:30:25 UTC
I made a mistake on my netro spark and included a rain delay from the main screen.
How can I delete this delay?
瀏覽: 8051   回覆: 1
Alvaro Guardado
更新時間 2023-05-08 18:25:58 UTC
Dear support,
瀏覽: 7606   回覆: 1
Whisperer GPS error
Guido Minciotti
更新時間 2023-05-10 15:11:55 UTC
瀏覽: 8223   回覆: 1
No light
Gabriele Gualtieri
更新時間 2023-05-10 17:13:50 UTC
瀏覽: 7836   回覆: 1
Bruno
更新時間 2023-05-10 22:41:29 UTC
瀏覽: 8309   回覆: 1
Anupam Kumar
更新時間 2023-05-11 00:29:18 UTC
瀏覽: 7573   回覆: 1
Nitro speak to system
Charlie Patel
更新時間 2023-05-11 18:55:33 UTC
瀏覽: 7593   回覆: 1
Whisperer wifi connection
Paolo S
更新時間 2023-05-12 15:41:24 UTC
Any suggestion?
Any issue with iphone 14?
瀏覽: 8122   回覆: 1
S R
更新時間 2023-05-13 00:02:22 UTC
瀏覽: 12439   回覆: 2
更新時間 2023-05-14 12:23:35 UTC
Kirk
瀏覽: 8440   回覆: 1
Jim Shields
更新時間 2023-05-15 21:20:33 UTC
瀏覽: 7726   回覆: 1
