Maximum watering duration for SPARK
Katarzyna Wrobel
更新時間 2023-04-11 22:55:50 UTC
Hi there :)
I want to set-up a watering duration for my desert garden (Phoenix, AZ). We should water our garden deeply and infrequently. So, I want to set-up a watering time of two hours. Unfortunately, the app has a maximum duration set to 60 minutes only. Any suggestions?
瀏覽: 7592   回覆: 1
Whisper will not factory reset!
Ross Brown
更新時間 2023-04-13 10:43:03 UTC
Hi I have had to send back my spark due to a problem with one zone not operating, I’m now trying to do a reset on my whisper, I have pressed the power button quickly 6 times, on numerous occasions and cannot get it to reset, any help would be much appreciated. New Spark arrived and working well, l just can’t seem to reset the Whisper no matter how many times I try the on/off 3 times. Are there any other action I could do or do I return it for a replacement?
瀏覽: 9980   回覆: 1
Suggestions and Question.
Maurizio Gianesin
更新時間 2023-04-12 15:08:32 UTC
Good morning.
I just started using Netro Sprite 8 zones out of 12 zones with two whisperers.
Congratulations for the App and the Web interface I'm using.
I have a concern about some trivial errors in the interfaces:
If you go to settings/preferences/SchedulingSetting
1.1 The Italian translation of "Two Frames" in "Due Cornici" makes me smile, it is better translated in "Due Cicli" or "Due Fasi". But my suggestion is also for English : it is my opinion that if instead of "Time Frames" and "Two Frames" you use "Time Phase" and "Two Phase" it is much better also for English and automatic translations free from misunderstandings.
1.2 Only in the App and not on the Web, the description of the two phases has "afternoon" under "morning" and vice versa.
Now I have a question:
I ask you for an explanation on Smart Scheduling.
I had set a lower limit of 10 C° and a Time Phase of 6:00 - 10:00. When I removed the 10 C° limit, the system did the same day a cycle at 23:58 instead of waiting for 6:00. why?
I hope I have been helpful and thank you for any response.
瀏覽: 7817   回覆: 1
Wasteful
David Maerzke
更新時間 2023-04-13 13:19:47 UTC
瀏覽: 7720   回覆: 1
carlos davalos melgar
更新時間 2023-04-13 20:06:46 UTC
瀏覽: 8044   回覆: 0
更新時間 2023-04-13 20:06:57 UTC
瀏覽: 10536   回覆: 0
更新時間 2023-04-13 20:07:05 UTC
瀏覽: 10329   回覆: 1
Matt Ward
更新時間 2023-04-14 13:57:11 UTC
Matt
瀏覽: 8408   回覆: 3
Intelligent mode useless
Juan Lambea
更新時間 2023-04-14 15:51:37 UTC
瀏覽: 10921   回覆: 1
dummy serial for testing
更新時間 2023-04-16 17:53:00 UTC
瀏覽: 8298   回覆: 1
Multiple users
Norm Markworth
更新時間 2023-04-17 00:22:59 UTC
Norm
瀏覽: 8893   回覆: 2
Pixie keeps disconnecting
Sang Peiris
更新時間 2023-04-18 12:44:42 UTC
瀏覽: 7951   回覆: 1
Add user Error
更新時間 2023-04-21 09:26:43 UTC
瀏覽: 7583   回覆: 2
farenheit to celsius
Santiago Moller
更新時間 2023-04-22 02:41:55 UTC
Hello, I need help to change the settings from Fahrenheit to Celsius in the app, I have a smart plant sensor.  Thank you
瀏覽: 8526   回覆: 1
Area
Javier Domínguez
更新時間 2023-04-22 16:04:10 UTC
Hola,
Cuando estoy configurando las zonas me pide un valor de area, ¿en qué medida? ¿Metros cuadrados?
瀏覽: 8015   回覆: 1
valves under relay
Alek
更新時間 2023-04-22 17:48:29 UTC
瀏覽: 10188   回覆: 1
Master error “open circuit”
Neil Lucey
更新時間 2023-04-24 14:09:12 UTC
Neil
瀏覽: 7769   回覆: 1
更新時間 2023-04-24 14:27:08 UTC
Sprite / app
Never before
Disconnection to wifi
Even when say : online
irrigation )
瀏覽: 8355   回覆: 1
Jim
更新時間 2023-04-24 17:38:25 UTC
瀏覽: 8129   回覆: 2
Katie Woggins
更新時間 2023-04-24 18:40:07 UTC
瀏覽: 7660   回覆: 1
