Windows 10 APP or web page
Emanuel Di Giusto
更新時間 2019-09-06 19:46:57 UTC
瀏覽: 8121   回覆: 1
Tony D.
更新時間 2019-09-09 12:57:04 UTC
瀏覽: 9001   回覆: 1
Feature request
Tony D.
更新時間 2019-09-12 20:32:30 UTC
Tony
瀏覽: 8625   回覆: 1
更新時間 2019-09-17 12:12:15 UTC
瀏覽: 9989   回覆: 1
Unit measurements
Homestead One
更新時間 2019-09-17 20:29:09 UTC
瀏覽: 8067   回覆: 1
Schedule setup
Rich Christenson
更新時間 2019-09-21 14:51:31 UTC
瀏覽: 8093   回覆: 1
Whisperer seems wrong
Tim Foster
更新時間 2019-09-22 15:02:12 UTC
I only got my system delivered yesterday, so this could be something that I doing wrong, I have one whisperer in the back garden and one in the front. I live in Merida Yucatan and so it's hot all the time. The whisperer in the back is in direct sunlight most of the day yet it's reporting the temperature as 24. The one in the front is shaded by the house yet that is reporting 33. Both seem to be reporting incorrect moisture levels in both the topsoil and subsoil. Yucatán drains through stone to underground water sources so I would expect both topsoil and subsoil to be showing very arid.
Can anyone advise?
瀏覽: 9627   回覆: 1
Tony D.
更新時間 2019-09-24 21:08:17 UTC
Hello everybody,
瀏覽: 8512   回覆: 1
Ip address
Kris Y
更新時間 2019-09-25 20:13:08 UTC
瀏覽: 8267   回覆: 1
Solid white light after install - HELP
Carlos Oliveira
更新時間 2019-09-25 20:29:08 UTC
I have just replaced a Rain bird image 6 by the Netro Sprite and I am using it's power supply.
The problem is that once I connect it after first install it gets to solid white light. I press reset shortly or even for 8 seconds but nothing changes.
Can someone help me ?
瀏覽: 9791   回覆: 1
Cold winter season and whisperer ?
Yves Desrosiers
更新時間 2019-09-26 11:12:56 UTC
We have to take back inside our home the whisperer when the cold season is back I guess ? At what  exterior tempeture we should do this ?
瀏覽: 11458   回覆: 3
hanz.blatt@gmail.com
更新時間 2019-09-29 13:59:02 UTC
瀏覽: 15064   回覆: 2
Nguyễn Vinh
更新時間 2019-09-30 06:46:55 UTC
瀏覽: 9984   回覆: 2
sqwu
更新時間 2019-09-30 13:51:09 UTC
瀏覽: 8494   回覆: 1
Installation Direct to pump
Tim Foster
更新時間 2019-10-03 11:23:32 UTC
I have the following:
瀏覽: 10097   回覆: 2
Weird watering plan
Manuel Roca
更新時間 2019-10-12 11:34:00 UTC
瀏覽: 7981   回覆: 1
Brian Hobbs
更新時間 2019-10-15 01:58:49 UTC
瀏覽: 9472   回覆: 1
Sangjin Lee
更新時間 2019-10-17 03:41:11 UTC
瀏覽: 8271   回覆: 1
What about blowout?
Burghardi
更新時間 2019-10-18 02:06:15 UTC
Why doesn’t this one?
瀏覽: 8274   回覆: 2
Riego netro para tepes
Manuel C
更新時間 2019-10-23 09:36:27 UTC
Hola,
瀏覽: 12480   回覆: 1
