Watering stop problem
lekter
更新時間 2020-02-14 14:43:36 UTC
When I start watering to give it a try. Everything's going well. But when I want to stop watering it's impossible. I have to turn off the power so that netro stops the watering.
WeatherPro is the problem ?
For information, I have an electrovanne rainbird.
Arnaud
瀏覽: 9319   回覆: 0
new dripping system using Pixie and Whisperer
Markus Matula
更新時間 2020-02-20 08:52:39 UTC
I am in the process of designing my dripping system for my beach house in FL. I am thinking about using 2 Pixies and several Whisperers. I have several questions: 1) What happens when the WIFI is down? Does Pixie turn watering off/on on its own? 2) Does Pixie skip a watering cycle when raining? 3) Are the Whisperers connected to the Pixie and App in that the humidity information guides the amount and frequency of watering? 4) What is the recommended soil humidity for new planted palm trees? Thanks, Markus
瀏覽: 8663   回覆: 1
App Crashes on adding product
Tarudro
更新時間 2020-02-24 20:24:10 UTC
I just received my Pixie and Whisperer and wanted to set them up using my iPhone.
Therefore I launch the app and go to "Add Product", select the Pixie and then I'm promted to enter my location and a name for the timer.
When I click on "next" the app crashes and returns to the home screen. 100% reproducible. I tried to enter different adress and name, but couldn't make it work. Crashes every time.
Reinstall also didn't solve the problem.
Netro App: 2.4.0
iPhone 11 Pro
iOS 13.3.1
German (also tried English)
Let me know, if you need anything else to reproduce/solve this issue or if there is something that I could do to prevent it.
So far, I couldn't find anything in the forum here.
BR Lukas
PS. I just tried also on my iPad Air 2 - same crash.
瀏覽: 15892   回覆: 4
Claude Bedarride
更新時間 2020-02-29 14:28:34 UTC
瀏覽: 7561   回覆: 1
Watering stops after 5 mins
D String
更新時間 2020-02-29 17:22:32 UTC
瀏覽: 8856   回覆: 1
Distance between controller and solenoid valves
Steve Cary
更新時間 2020-03-01 14:42:55 UTC
My controller will be about 20 meters from the solenoids.  What size cable do I need to make this work? Thankyou!!
瀏覽: 9004   回覆: 1
Carlo D'Ippolito
更新時間 2020-03-01 14:55:14 UTC
Waiting for your feedback.
Kind regards
瀏覽: 8812   回覆: 1
Is it working correctly? 0v test multimeter
yodiego
更新時間 2020-03-07 12:14:59 UTC
Hi good morning,
I’m making the first installation and I see the valves don’t open when I tested it, so I test the connections with a multi-meter and sometimes it gives 24v and sometimes 0.
The last 10 tries it gives 0. I changed the cables and I now I test directly the controller connections and keep giving me 0.
I’m using the manual watering to make the tests.
Thank you for your help.
瀏覽: 9151   回覆: 1
alexa & pixie
stefano banfi gaslini
更新時間 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
瀏覽: 7844   回覆: 1
Benedetto
更新時間 2020-03-11 14:44:38 UTC
Thanks for the support
Br
BG
瀏覽: 9379   回覆: 1
Sprinkler is on during rain
Wahid Ameni
更新時間 2020-03-14 00:12:38 UTC
瀏覽: 7845   回覆: 1
Delivering term please
yodiego
更新時間 2020-03-14 18:08:21 UTC
瀏覽: 7497   回覆: 1
Whisperer issue
Saul Perez
更新時間 2020-03-15 19:07:50 UTC
瀏覽: 9020   回覆: 1
Javier Palomino
更新時間 2020-03-18 02:11:35 UTC
瀏覽: 7466   回覆: 1
更新時間 2020-03-18 15:16:20 UTC
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
瀏覽: 9285   回覆: 1
Instalación wifi
Eduardo Pariente
更新時間 2020-03-20 16:15:47 UTC
Good afternoon.
 I have problems because I don't recognize the wifi.  I'll explain. First I connect by wifi to netro and it does not give me any problems.  But when I go back to the next screen to connect the mobile to the wifi and the wifi from home no longer appears. He's gone. And I can't continue with the installation.
瀏覽: 9124   回覆: 1
Yohan
更新時間 2020-03-22 00:49:00 UTC
瀏覽: 9485   回覆: 1
Smart scheduling problem
更新時間 2020-03-23 19:15:51 UTC
This is my set up.
1) why this happened?
瀏覽: 8393   回覆: 1
Giacomo
更新時間 2020-03-24 14:44:34 UTC
Thanks in advance
瀏覽: 8702   回覆: 1
J H
更新時間 2020-03-24 21:16:47 UTC
瀏覽: 7523   回覆: 1
