Garden
Steven Carnie
更新時間 2020-03-26 14:53:02 UTC
瀏覽: 12868   回覆: 1
Max V
更新時間 2020-03-27 18:52:10 UTC
Hi everyone!
瀏覽: 12455   回覆: 1
duerson
更新時間 2020-03-27 20:59:20 UTC
瀏覽: 8032   回覆: 1
2 or more zone at same time
Mirko Paganelli
更新時間 2020-03-28 15:32:05 UTC
瀏覽: 7941   回覆: 1
Run Netro in one zone now
Stan Bumgarner
更新時間 2020-03-28 20:15:35 UTC
Stan
瀏覽: 7560   回覆: 1
Rain adjustment
Arvind Ramanadham
更新時間 2020-03-31 19:10:38 UTC
瀏覽: 8265   回覆: 1
Dark Sky
Vardhan Rajkumar
更新時間 2020-04-01 21:55:47 UTC
瀏覽: 8289   回覆: 2
Installing Pixie
kristinsavage
更新時間 2020-04-03 21:25:20 UTC
I am trying to install my Netro Pixie and the vacuum breaker is blocking the filter on the Pixie. Any suggestions?
瀏覽: 9284   回覆: 1
power adaptor
更新時間 2020-04-04 14:39:25 UTC
just received a Netro Sprite controller 12 sone without power adapter
I am in Rome , Italy
We have 240 volts energy supply
what adapter have i to buy ?
thanks
paolo
瀏覽: 9869   回覆: 2
Joe Ryan
更新時間 2020-04-05 17:48:32 UTC
瀏覽: 8355   回覆: 1
Casey S
更新時間 2020-04-05 19:41:30 UTC
瀏覽: 9516   回覆: 1
Home Assistant integration
Casey S
更新時間 2020-04-05 19:46:53 UTC
瀏覽: 8449   回覆: 2
Host mode
Luca Manfrin
更新時間 2020-04-06 17:55:38 UTC
What is host mode?
瀏覽: 9776   回覆: 1
Settings
Massimo Povolo
更新時間 2020-04-07 06:31:48 UTC
瀏覽: 8791   回覆: 5
Luca Manfrin
更新時間 2020-04-07 09:19:37 UTC
瀏覽: 8184   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:22:40 UTC
瀏覽: 8194   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:28:22 UTC
瀏覽: 8208   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:33:03 UTC
瀏覽: 9317   回覆: 1
Irrigation time of 0 minutes. then?
Luca Manfrin
更新時間 2020-04-07 09:37:54 UTC
What's the point option to set the irrigation time at 0 minutes in manual execution?
It would be more useful a 30 seconds run for testing the valves.
瀏覽: 9492   回覆: 1
Luca Manfrin
更新時間 2020-04-07 10:07:29 UTC
-SKIP FOR TODAY
瀏覽: 7877   回覆: 1
