Irrigation time striketrough
Luca Manfrin
更新時間 2020-04-07 12:34:22 UTC
thank you
瀏覽: 7557   回覆: 1
Seb Cruzer
更新時間 2020-04-07 15:03:43 UTC
hello,
Please help!
瀏覽: 9256   回覆: 2
Power adapter - eu
David B.
更新時間 2020-04-08 13:43:20 UTC
I have a netro sprite with an original power adapter.
How ca i connet this to my 220/230 Volt energynet in Austria pls?
A normal Adapter will not work since i have to tansform volt and ampere to 800ma and 110volt as far as i could find informations.
Kind regards david
瀏覽: 9284   回覆: 1
Resetting Netro Whisperer
Patrick
更新時間 2020-04-09 19:34:52 UTC
瀏覽: 9013   回覆: 1
Incorrect weather conditions
Andrea Merito
更新時間 2020-04-09 20:33:11 UTC
as the state / province is changed because Madrid is specified instead of Catania, consequently the weather is incorrect.
瀏覽: 8976   回覆: 1
Luca Manfrin
更新時間 2020-04-10 11:43:03 UTC
瀏覽: 9374   回覆: 2
Netro app on google home
Danilo
更新時間 2020-04-11 10:07:58 UTC
Thanks for your support.
瀏覽: 7326   回覆: 1
Brett Lilly
更新時間 2020-04-13 18:42:28 UTC
瀏覽: 7510   回覆: 1
Faucet Connector Broke
Larry Griggers
更新時間 2020-04-14 18:49:27 UTC
I was having difficulty getting a leakproof seal when attaching my Smart Hose Faucet Timer (Pixie-1) to my new faucet. I finally was able to tighten it tight enough not to leak, but after a week, it broke and popped off. It is probably under warranty, but is there somewhere I can buy a new connector and repair it myself?
瀏覽: 8636   回覆: 1
Luca Manfrin
更新時間 2020-04-16 07:47:25 UTC
Thank you for your support
瀏覽: 7689   回覆: 2
Luca Manfrin
更新時間 2020-04-16 10:23:31 UTC
thank you
瀏覽: 7703   回覆: 1
Range of whisperer
Fraco
更新時間 2020-04-16 19:35:32 UTC
Is there a maximum distance I can place the whisperer(s) in the garden. Largest distance it should cover is approx. 30 mtrs.
The sprite probably will be placed inside.
瀏覽: 10076   回覆: 1
Which Alexa app?
jbart65
更新時間 2020-04-16 20:00:55 UTC
Jeffry
瀏覽: 7561   回覆: 1
Max V
更新時間 2020-04-17 09:46:19 UTC
瀏覽: 8883   回覆: 1
Keep Connected option
jbart65
更新時間 2020-04-17 17:38:10 UTC
The particulars:
瀏覽: 7453   回覆: 1
Forecast vs Expectation
Arvind Ramanadham
更新時間 2020-04-17 18:25:49 UTC
瀏覽: 8007   回覆: 1
Mixed Plant Zone
Rich Keith
更新時間 2020-04-18 23:36:39 UTC
瀏覽: 7195   回覆: 1
Netro-Community using App
Lou Infeld
更新時間 2020-04-19 13:46:12 UTC
瀏覽: 8436   回覆: 1
Pixie Leaks
Rich Keith
更新時間 2020-04-19 17:18:48 UTC
瀏覽: 8704   回覆: 1
How protect Netro Sprite
Stefano Carucci
更新時間 2020-04-21 09:14:57 UTC
I need to install the Netro Sprite in a tool shed covered by tiles and closed only on three sides that I have in the garden (L 2mt, W 1.5mt, H 1.8mt).
I would like to know if, to protect it from humidity, dust and insects, I can install it in a box like this:
https://www.amazon.com/Fielect-Transparent-Switchboard-Distribution-115x90x50mm/dp/B07ZR2HN5B/ref=sr_1_17?dchild=1&keywords=transparent%2BDistribution%2Bbox&qid=1587458726&rnid=2941120011&s=hi&sr=1-17&th=1
and if this box can decrease the reception of the wifi signal.
瀏覽: 9575   回覆: 1
