Not able to water
更新时间 2019-03-27 13:18:49 UTC
浏览: 9999   回复: 1
controller firmware
Magnus Swenson
更新时间 2019-03-27 19:55:40 UTC
Does the controller update its own firmware automatically on a specific schedule or you push out when needed?
浏览: 10227   回复: 1
windy conditions
Magnus Swenson
更新时间 2019-03-27 20:05:53 UTC
The setting for windy conditions is great.
However the zones that includes drip irrigation doesn’t get impacted by winds (since they’re often under dirt/mulch etc) usually rotors and nozzles would be impacted . Is there a way not to include in ground drip irrigation on windy conditions?
浏览: 9535   回复: 1
MAC address
Lee Hill
更新时间 2019-03-29 15:45:44 UTC
浏览: 9664   回复: 1
Smart home integration
Matt Griste
更新时间 2019-03-29 22:29:57 UTC
浏览: 9814   回复: 2
Smart Watering Basic with a schedule watering adjustment
Barry Perfect
更新时间 2019-04-13 17:00:37 UTC
If I have a zone set to Smart Watering - Basic with a schedule to come on for 30 minutes, will the smart watering adjust the duration of the watering based on the weather (say 10 minutes when it’s cool, the full 30 minutes when it is hot), or just turn it off/on based on the 5mm expected rain threshold?
Barry
浏览: 9119   回复: 1
Suggestion: Sunrise smart watering
Mark S
更新时间 2019-04-15 13:39:43 UTC
I think Rachio adjusts the watering schedule with sunrise to have all zones completed as the sun is coming up. Is this something you intend to add? I think this will come in handy with the heat of summer.
浏览: 9483   回复: 1
更新时间 2019-04-20 12:21:46 UTC
Mr Bad Example
浏览: 9781   回复: 1
Weather Company API- Revenue stream for Netro
更新时间 2019-04-20 12:58:20 UTC
It is my understanding that you could restore our ability to pull data into netro from our individual weather stations. This would require paying for the API, which you could mark up 20% and offer a paid option to netro clients. $3.99 a year, for example, would be totally worth it to get accurate information to my sprinkler controller. As I have outlined in a previous post, dark sky has proven to be wildly inaccurate. It's Miss estimates rainfall by at least 50%, on average, and is within three degrees plus or minus on high temperature only about 50% of the time.
浏览: 10581   回复: 4
John Mac
更新时间 2019-04-22 23:42:30 UTC
浏览: 9034   回复: 1
Alexa
Emilio Maione
更新时间 2019-04-24 06:50:56 UTC
浏览: 9519   回复: 1
Answers?
Howard Blankenship
更新时间 2019-04-24 14:46:54 UTC
浏览: 8834   回复: 1
Service account
ltanase13
更新时间 2019-04-25 01:26:55 UTC
浏览: 9289   回复: 1
One sensor for multiple zones
bdcfam
更新时间 2019-05-01 01:28:20 UTC
Is there a way to assign one sensor to multiple zones?
浏览: 13236   回复: 2
Connecting Hunter PVG-Valves
John Mayer
更新时间 2019-05-01 15:57:37 UTC
I am trying to connect my Hunter PVG 101 GB valves to my new Metro Sprite.
I haven't installed a watering System before so I am quite a newbie here.
I have managed to set my Sprite up. But my valves aren't working.
I have double checked my wires. No issue there. As I am living in Germany I have bought my own power supply. It's this one: INNOVATE LED Trafo ECO 24 Volt/DC, 0-50W - LED Treiber - Transformator - Netzteil - Driver (24V - 50W) https://www.amazon.de/dp/B01AALEYR8/ref=cm_sw_r_cp_apa_i_LgCYCb2PT86Y9
Are there any recommendations, what I could do wrong?
Thanks so much,
浏览: 10428   回复: 2
Graphs
Jim Bethea
更新时间 2019-05-04 11:25:22 UTC
浏览: 9046   回复: 1
John Locke
更新时间 2019-05-05 14:16:12 UTC
浏览: 9584   回复: 1
Henry
更新时间 2019-05-06 19:40:59 UTC
same issue...
so what to do with it?
浏览: 9597   回复: 2
is the Pixie faucet joint (both in and out) GHT (Garden Hose Thread) or NPT (National Pipe Thread)
Oliver Pettit
更新时间 2019-05-09 01:33:23 UTC
Could you please confirm if the Pixie faucet joint is GHT (garden hose thread) or is it NPT (National Pipe Thread)?
I'm looking for adapters in Australia to use this unit and its unclear what the size/type the faucet is.
浏览: 9889   回复: 1
Problemi con Google home
Max Point
更新时间 2019-05-12 08:36:40 UTC
Massimo
浏览: 9365   回复: 1
