Smart watering at wrong time
Joakim Björn
Actualizado 2020-04-21 19:55:37 UTC
Hello!
Ver: 7391   Respuesta: 1
google home not connected
maxtrash
Actualizado 2020-04-21 23:01:57 UTC
what could be going on?
Ver: 7577   Respuesta: 2
Best sync option?
jbart65
Actualizado 2020-04-22 02:56:17 UTC
Ver: 7846   Respuesta: 1
Whisperer ans sprite zone
lekter
Actualizado 2020-04-23 14:40:17 UTC
When i install the whisperer sensor i can’t choose a zone. The installation begin without possibilities to choose.
The sensor is ok but it is not paires dithyrambiques a zone.
how i can do please ?
I leave un France
Ver: 9891   Respuesta: 1
Gian Piero Pepino
Actualizado 2020-04-25 09:23:06 UTC
Gian Piero
Ver: 7641   Respuesta: 1
Plant Sensor
Ntenaive
Actualizado 2020-04-25 21:56:51 UTC
Ver: 8265   Respuesta: 2
Problem with controling relay
Srdjan
Actualizado 2020-04-26 06:54:18 UTC
Hi, i try to control working water pump by M contact on controler using relay(24VAC) and that is not posible, I try with three different relays and same situation.
Is anybody have same or similary problem and if anybody use M contact for controling relay please send tehnical data or picture of that releay that I can buy same... Suporrt not answering on this question I send them video of working two different relays but not got answer...
I tru to upload video here but that is not posible...
Thank for help.
Ver: 9026   Respuesta: 1
Carlo Monico
Actualizado 2020-04-26 06:59:36 UTC
Grazie.
Ver: 7489   Respuesta: 1
Carlo D'Ippolito
Actualizado 2020-04-27 13:16:32 UTC
Waiting for a solution
Carlo
Ver: 7514   Respuesta: 0
Cam
Actualizado 2020-04-29 19:55:03 UTC
Ver: 7428   Respuesta: 0
New plant/seeding setting
Cody Cant
Actualizado 2020-04-30 04:57:11 UTC
Is there or could there be a feature to turn on a watering schedule that accommodates for new plants or seedlings that require a bit more water at first and then can be put into a normal schedule?
Ver: 8937   Respuesta: 1
Selezione tipologia prato
Marco
Actualizado 2020-04-30 06:49:27 UTC
buongiorno
Volevo sapere cortesemente in Italia centrale  Roma che tipo di erba selezionare nelle zone.
M.
Ver: 9544   Respuesta: 1
Schedule OFF
B S
Actualizado 2020-04-30 11:16:12 UTC
Ver: 7379   Respuesta: 1
Watering when zones are off
Ben Wojcik
Actualizado 2020-05-02 13:07:30 UTC
I turned off all my zones, but my netro still stays is watering.  How do I get it to stop doing this?  I can't figure out what its watering either.
Ver: 9744   Respuesta: 1
Sprinklers don’t work
Richard Mundy
Actualizado 2020-05-02 18:59:26 UTC
Please help
Ver: 8180   Respuesta: 1
Subsoil humidity
Massimo Povolo
Actualizado 2020-05-03 07:21:37 UTC
Dear sirs,
why you don't show the subsoil humidity in the app?
Please add in next revision.
Ver: 9271   Respuesta: 1
I want to increase watering time since it only says 2:00 minutes (it works for this time) but am unable to increase/change it. Please help. Please help!
Anne Knudsen
Actualizado 2020-05-03 16:47:04 UTC
I can not change the time (number of minutes) for watering to happen. please help.
Two of the zones are 45 minutes and 60 minutes and they work.
Ver: 9031   Respuesta: 1
Connect the zones
Alessio Martini
Actualizado 2020-05-03 17:42:25 UTC
Ver: 7639   Respuesta: 1
Sprite app says its watering but it is not
Jen Morgan
Actualizado 2020-05-03 18:02:31 UTC
It has been working for 3 weeks, but now it does not.
I have checked all 7 zones. No wiring issues. Has proper voltage.
It just won't come on. How do I get it to work again. This is a new unit. Sprinklers are all fine and had a tune up when the Sprite was installed.
I have unplugged it and plugged it back in. I need help soon, I have new sod and many new plants in my yard and gardens.
Ver: 7713   Respuesta: 1
Andrea Merito
Actualizado 2020-05-04 13:18:10 UTC
hello,
finally the Whisperer sensors are wonderful.  I installed the 3 sensors divided by zones, a single problem that I encountered is this: the sensor that I called Prato should group 4 zones because they are part of the same type of plant, instead it only groups 3 zones.  I need your help.
Andrea
Ver: 10446   Respuesta: 2
