No 2.4GHz wifi
Carlos Oliveira
Actualizado 2020-05-16 11:29:24 UTC
My netro has been working fine for the past many months.
Suddenly it stopped working and light blinks.
I try to configure the Wifi again and it states
I am sure my 2.4 GHz network is available there as I have 2 other devices 10 Cm away from the netro and are working fine at 2.4GHz
I can confirm that in my Orbi Router.
Any ideas ?
Carlos
Ver: 10852   Respuesta: 1
Link to smart light
Noam Leshem
Actualizado 2020-05-16 17:53:06 UTC
Ver: 8096   Respuesta: 1
EASTBOBDAM D
Actualizado 2020-05-17 13:18:19 UTC
Thanks in advance
Ver: 7499   Respuesta: 1
Yves Desrosiers
Actualizado 2020-05-17 18:31:27 UTC
Thanks for your help :)
Ver: 7974   Respuesta: 1
Watering program
Maciej Karpinski
Actualizado 2020-05-18 01:01:57 UTC
Ver: 9196   Respuesta: 1
Pixie sync Sprite
Sebastian Diaz
Actualizado 2020-05-19 02:50:59 UTC
Thanks you Sebastian
Ver: 8458   Respuesta: 1
Kobus Marneweck
Actualizado 2020-05-19 03:33:33 UTC
Ver: 7887   Respuesta: 1
Best settings for garden
Alexandre Morin
Actualizado 2020-05-20 11:01:20 UTC
thanks
Ver: 8706   Respuesta: 2
Roman Prochazka
Actualizado 2020-05-22 07:55:46 UTC
Many thanks for early answer
Best Regards
Roman
Ver: 8507   Respuesta: 2
Wayne Richards
Actualizado 2020-05-23 16:07:26 UTC
Ver: 7882   Respuesta: 1
Rearranging zones?
Kurt H
Actualizado 2020-05-23 19:17:20 UTC
Ver: 8411   Respuesta: 1
Pressure compensated drip hose
Simon Clark
Actualizado 2020-05-24 17:22:21 UTC
I use Netafin pressure compensated drip hose on all my beds and there doesn’t seem To be an irrigation type for that. Is it OK using the drip setting which seems to be for micro drippers.
Ver: 10699   Respuesta: 0
Chris Graham
Actualizado 2020-05-24 20:37:39 UTC
Ver: 8342   Respuesta: 1
Is a full time wifi connection required for watering? Or any other unattended modes of failure?
Chris Graham
Actualizado 2020-05-24 20:43:23 UTC
If wifi is disrupted will the controller continue to water acording to the most recently programmed schedules?
More generally are there any modes of failure (other than loss of power to the house) where the controller can unexpectedly halt watering?  It would be unacceptable to have one's garden die from lack of water if the system fails when one is away from home for a number of days.
Ver: 9689   Respuesta: 1
Actualizado 2020-05-25 16:08:09 UTC
Ver: 7809   Respuesta: 1
Web interface
Emanuele Floridia
Actualizado 2020-05-27 16:58:10 UTC
Ver: 8218   Respuesta: 1
Delay between zones
Nicholas Lydakis
Actualizado 2020-05-28 15:39:00 UTC
Ver: 7699   Respuesta: 1
baijuviswam
Actualizado 2020-05-28 18:56:02 UTC
Ver: 7412   Respuesta: 1
Jesse For
Actualizado 2020-05-29 08:33:36 UTC
Ver: 7450   Respuesta: 1
Missing Whisperer
guags99
Actualizado 2020-05-29 18:11:36 UTC
This season when I put my whisperer back out to monitor my garden bed I looked on the app and no longer saw that device. So I went through the process to re-add it to my network and my Netro account and I get an error message stating that that serial number is already registered.  Anyone have any thoughts on how I can de-register and re-register this device?  Thanks
Ver: 10285   Respuesta: 1
