Watering stop problem
lekter
Actualizado 2020-02-14 14:43:36 UTC
When I start watering to give it a try. Everything's going well. But when I want to stop watering it's impossible. I have to turn off the power so that netro stops the watering.
WeatherPro is the problem ?
For information, I have an electrovanne rainbird.
Arnaud
Ver: 9309   Respuesta: 0
new dripping system using Pixie and Whisperer
Markus Matula
Actualizado 2020-02-20 08:52:39 UTC
I am in the process of designing my dripping system for my beach house in FL. I am thinking about using 2 Pixies and several Whisperers. I have several questions: 1) What happens when the WIFI is down? Does Pixie turn watering off/on on its own? 2) Does Pixie skip a watering cycle when raining? 3) Are the Whisperers connected to the Pixie and App in that the humidity information guides the amount and frequency of watering? 4) What is the recommended soil humidity for new planted palm trees? Thanks, Markus
Ver: 8646   Respuesta: 1
App Crashes on adding product
Tarudro
Actualizado 2020-02-24 20:24:10 UTC
I just received my Pixie and Whisperer and wanted to set them up using my iPhone.
Therefore I launch the app and go to "Add Product", select the Pixie and then I'm promted to enter my location and a name for the timer.
When I click on "next" the app crashes and returns to the home screen. 100% reproducible. I tried to enter different adress and name, but couldn't make it work. Crashes every time.
Reinstall also didn't solve the problem.
Netro App: 2.4.0
iPhone 11 Pro
iOS 13.3.1
German (also tried English)
Let me know, if you need anything else to reproduce/solve this issue or if there is something that I could do to prevent it.
So far, I couldn't find anything in the forum here.
BR Lukas
PS. I just tried also on my iPad Air 2 - same crash.
Ver: 15867   Respuesta: 4
Claude Bedarride
Actualizado 2020-02-29 14:28:34 UTC
Ver: 7548   Respuesta: 1
Watering stops after 5 mins
D String
Actualizado 2020-02-29 17:22:32 UTC
Ver: 8844   Respuesta: 1
Distance between controller and solenoid valves
Steve Cary
Actualizado 2020-03-01 14:42:55 UTC
My controller will be about 20 meters from the solenoids.  What size cable do I need to make this work? Thankyou!!
Ver: 8991   Respuesta: 1
Carlo D'Ippolito
Actualizado 2020-03-01 14:55:14 UTC
Waiting for your feedback.
Kind regards
Ver: 8795   Respuesta: 1
Is it working correctly? 0v test multimeter
yodiego
Actualizado 2020-03-07 12:14:59 UTC
Hi good morning,
I’m making the first installation and I see the valves don’t open when I tested it, so I test the connections with a multi-meter and sometimes it gives 24v and sometimes 0.
The last 10 tries it gives 0. I changed the cables and I now I test directly the controller connections and keep giving me 0.
I’m using the manual watering to make the tests.
Thank you for your help.
Ver: 9141   Respuesta: 1
alexa & pixie
stefano banfi gaslini
Actualizado 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
Ver: 7831   Respuesta: 1
Benedetto
Actualizado 2020-03-11 14:44:38 UTC
Thanks for the support
Br
BG
Ver: 9367   Respuesta: 1
Sprinkler is on during rain
Wahid Ameni
Actualizado 2020-03-14 00:12:38 UTC
Ver: 7832   Respuesta: 1
Delivering term please
yodiego
Actualizado 2020-03-14 18:08:21 UTC
Ver: 7487   Respuesta: 1
Whisperer issue
Saul Perez
Actualizado 2020-03-15 19:07:50 UTC
Ver: 9007   Respuesta: 1
Javier Palomino
Actualizado 2020-03-18 02:11:35 UTC
Ver: 7457   Respuesta: 1
Actualizado 2020-03-18 15:16:20 UTC
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
Ver: 9275   Respuesta: 1
Instalación wifi
Eduardo Pariente
Actualizado 2020-03-20 16:15:47 UTC
Good afternoon.
 I have problems because I don't recognize the wifi.  I'll explain. First I connect by wifi to netro and it does not give me any problems.  But when I go back to the next screen to connect the mobile to the wifi and the wifi from home no longer appears. He's gone. And I can't continue with the installation.
Ver: 9115   Respuesta: 1
Yohan
Actualizado 2020-03-22 00:49:00 UTC
Ver: 9476   Respuesta: 1
Smart scheduling problem
Actualizado 2020-03-23 19:15:51 UTC
This is my set up.
1) why this happened?
Ver: 8386   Respuesta: 1
Giacomo
Actualizado 2020-03-24 14:44:34 UTC
Thanks in advance
Ver: 8693   Respuesta: 1
J H
Actualizado 2020-03-24 21:16:47 UTC
Ver: 7512   Respuesta: 1
