Windows 10 APP or web page
Emanuel Di Giusto
Actualizado 2019-09-06 19:46:57 UTC
Ver: 8147   Respuesta: 1
Tony D.
Actualizado 2019-09-09 12:57:04 UTC
Ver: 9031   Respuesta: 1
Feature request
Tony D.
Actualizado 2019-09-12 20:32:30 UTC
Tony
Ver: 8646   Respuesta: 1
Actualizado 2019-09-17 12:12:15 UTC
Ver: 10010   Respuesta: 1
Unit measurements
Homestead One
Actualizado 2019-09-17 20:29:09 UTC
Ver: 8095   Respuesta: 1
Schedule setup
Rich Christenson
Actualizado 2019-09-21 14:51:31 UTC
Ver: 8119   Respuesta: 1
Whisperer seems wrong
Tim Foster
Actualizado 2019-09-22 15:02:12 UTC
I only got my system delivered yesterday, so this could be something that I doing wrong, I have one whisperer in the back garden and one in the front. I live in Merida Yucatan and so it's hot all the time. The whisperer in the back is in direct sunlight most of the day yet it's reporting the temperature as 24. The one in the front is shaded by the house yet that is reporting 33. Both seem to be reporting incorrect moisture levels in both the topsoil and subsoil. Yucatán drains through stone to underground water sources so I would expect both topsoil and subsoil to be showing very arid.
Can anyone advise?
Ver: 9665   Respuesta: 1
Tony D.
Actualizado 2019-09-24 21:08:17 UTC
Hello everybody,
Ver: 8542   Respuesta: 1
Ip address
Kris Y
Actualizado 2019-09-25 20:13:08 UTC
Ver: 8290   Respuesta: 1
Solid white light after install - HELP
Carlos Oliveira
Actualizado 2019-09-25 20:29:08 UTC
I have just replaced a Rain bird image 6 by the Netro Sprite and I am using it's power supply.
The problem is that once I connect it after first install it gets to solid white light. I press reset shortly or even for 8 seconds but nothing changes.
Can someone help me ?
Ver: 9821   Respuesta: 1
Cold winter season and whisperer ?
Yves Desrosiers
Actualizado 2019-09-26 11:12:56 UTC
We have to take back inside our home the whisperer when the cold season is back I guess ? At what  exterior tempeture we should do this ?
Ver: 11489   Respuesta: 3
hanz.blatt@gmail.com
Actualizado 2019-09-29 13:59:02 UTC
Ver: 15103   Respuesta: 2
Nguyễn Vinh
Actualizado 2019-09-30 06:46:55 UTC
Ver: 10005   Respuesta: 2
sqwu
Actualizado 2019-09-30 13:51:09 UTC
Ver: 8518   Respuesta: 1
Installation Direct to pump
Tim Foster
Actualizado 2019-10-03 11:23:32 UTC
I have the following:
Ver: 10122   Respuesta: 2
Weird watering plan
Manuel Roca
Actualizado 2019-10-12 11:34:00 UTC
Ver: 8008   Respuesta: 1
Brian Hobbs
Actualizado 2019-10-15 01:58:49 UTC
Ver: 9499   Respuesta: 1
Sangjin Lee
Actualizado 2019-10-17 03:41:11 UTC
Ver: 8297   Respuesta: 1
What about blowout?
Burghardi
Actualizado 2019-10-18 02:06:15 UTC
Why doesn’t this one?
Ver: 8300   Respuesta: 2
Riego netro para tepes
Manuel C
Actualizado 2019-10-23 09:36:27 UTC
Hola,
Ver: 12508   Respuesta: 1
