Info function
Giuseppe
Actualizado 2025-09-20 09:48:50 UTC
Ver: 5625   Respuesta: 1
I want to change wifi network my Netro controller is connected too.
loro
Actualizado 2025-09-23 21:27:44 UTC
How do I change the wifi network my Netro controller is connected too? I cannot proceed beyond step 2 from the instructions on the app. I get the message "Please connect to Wi-fi network "Netro_IRC_xxx."  However, the app shows that I am already connected!!
Ver: 5524   Respuesta: 1
Whisperer installation
Davide Chelo
Actualizado 2025-09-26 11:38:17 UTC
Hi, I just bought the whisperer 2 and would like to have it as only sensor for the entire garden, however is allowed to have maximum 3 zones for sensor. Is there a way to link all the zones to it? I have 7 zones.
Ver: 5004   Respuesta: 1
Password
Ignacio Sánchez
Actualizado 2025-09-26 11:38:52 UTC
Ver: 5114   Respuesta: 1
Actualizado 2025-10-08 13:12:52 UTC
Ver: 4478   Respuesta: 2
Problem: Spark 16 controller stuck on "in communication"
Corrado
Actualizado 2025-10-08 13:48:10 UTC
I'm experiencing a serious issue with my Netro Spark 16 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
The problemm is with the 4g Vodafone/HoMobile provider as yout mentioned in https://netrohome.com/en/forum/posts/4052
I have already asked several time the update for the device, but nobody reply me
i wrote also to Netro support email: support@netrohome.com  --> nobody reply me.
What should i do to have this update?
Please
Ver: 4350   Respuesta: 1
End of Season Shut down
Jayme Buhlman
Actualizado 2025-10-10 17:59:16 UTC
Hi, it’s the end of our watering season where I live, the city just shut off the water for the year. Any guidance on what to do in the app to have the system off for until spring?
Is it a good idea to unplug it for the season or no?
Ver: 4847   Respuesta: 1
L irrigazione non parte
Marco Michelini
Actualizado 2025-10-11 15:55:45 UTC
Hi, dopo aver collegato tutto, ho provato a fare un test manuale ma non parte l irrigazione.
Sapete aiutarmi?
Ver: 4406   Respuesta: 1
App crash
Nick
Actualizado 2025-10-12 20:41:50 UTC
The app crashea when I click on a zone on Google pixel 8a. I had to configure them with another phone. Already tried to reinstall the app and clear cache
Ver: 4633   Respuesta: 1
Wind preference for drippers
Troy Robertson
Actualizado 2025-10-17 06:46:57 UTC
Hey,
Is it possible to individually choose preferences for wind speed on a zone by zone basis? I've got some zones that are connected to sprayers which I would like to keep on a wind speed cutout and but most zones are on drippers which I would like to water independent of the wind speed.
Ver: 4449   Respuesta: 1
Seeding my lawn this week... How do I adjust the "New Plant" option for consistent watering?
Jonathan B.
Actualizado 2025-10-20 22:59:45 UTC
Hi... since it's still fairly warm outside, I'd like to have the Zone water every 2 hrs for about 3 minutes just to keep the ground moisture up.
I'm not clear on how to do this?  Anyone?
Ver: 4549   Respuesta: 1
Zone flexibility
Mike R
Actualizado 2025-10-29 01:20:50 UTC
I have a hill that was terraced and replanted. I was told to run the circuit twice a day for 15 minutes for a month. Drip lines. Seems like my system doesn’t have that flexibility. Am i correct?
Ver: 4322   Respuesta: 1
API broken?
Tortfeaser
Actualizado 2025-11-21 04:58:13 UTC
Hi, I can get my Netro controller info using:
curl -v https://api.netrohome.com/npa/v2/info.json?key=MYAPIKEY
(where MYAPIKEY is a key from the user account page)
but when I try to update soil moisture data with:
curl -X POST -H "Accept: application/json" -H 'Content-Type:application/json' -d '{"key":"MYAPIKEY","moisture":100}' "https://api.netrohome.com/npa/v2/set_moisture.json"
I get an error about an invalid key:
{"status":"ERROR","meta":{"time":"2025-11-21T04:54:56","tid":"1763700896_KpmY","version":"2.0","token_limit":0,"token_remaining":0,"last_active":"2025-11-21T04:54:56","token_reset":"2025-11-22T00:00:00"},"errors":[{"code":1,"message":"Invalid key: ","params":{}}]}
What's going on?
Ver: 16303   Respuesta: 1
Cannot add pixie z1
John R
Actualizado 2025-12-09 02:23:46 UTC
I cannot add my pixie z1 to the app because pixie z1 is not shown as an option. I have the hub connected.
Ver: 4086   Respuesta: 1
Watering on wrong day
keller3987
Actualizado 2025-12-09 15:39:44 UTC
I have programmed my Netro to skip Tuesday’s but the controller waters anyway. How do I stop this?
Ver: 3921   Respuesta: 1
The average temperature for a day is insufficient to calculate correct watering.
Richard
Actualizado 2025-12-17 07:17:57 UTC
When I have Whisperers, the system appears to calculate the average over the day about 4 degrees higher than for zones without Whisperers.
It seems that, even though the weather data is available throughout the day, that zones without sensors only use the forecast high and low.
This is insufficient to correctly adjust for the amount of watering required.
For example, today is 7 degrees C up to 36.
Whisperer zones average the temp at 26C while non-Whisperer zone calculate the average at 22C.
On these extremely hot days, the non-whisperer zones are under-watering much more than the Whisperer zones.
Also note that even the zones with Whisperers always under-water and needs custom programs or manual intervention.
This finally explains to me why zones are always under-watered.
Can the system please use multiple day readings for non-Whisperer zones and PLEASE provide more watering?
Ver: 3943   Respuesta: 2
Eric Jonsson
Actualizado 2026-01-08 12:02:58 UTC
Ver: 3916   Respuesta: 1
Shane V
Actualizado 2026-01-19 04:54:45 UTC
Ver: 3758   Respuesta: 1
Old whisperer
Actualizado 2026-01-20 10:38:33 UTC
Seems a communication problem
Ver: 3655   Respuesta: 1
Tuan Phan
Actualizado 2026-01-25 18:28:34 UTC
Ver: 3523   Respuesta: 1
