Will
Actualizado 2026-01-27 03:13:26 UTC
Ver: 3709   Respuesta: 1
cpline
Actualizado 2026-02-02 17:04:38 UTC
Ver: 3723   Respuesta: 1
Notification
Alexis Demosthenous
Actualizado 2026-02-05 19:28:19 UTC
Ver: 3767   Respuesta: 1
Will
Actualizado 2026-03-17 21:54:57 UTC
Ver: 4422   Respuesta: 3
Sensor to zone
Mark Zeck
Actualizado 2026-02-05 23:17:03 UTC
How do I connect my sensors to zones? I have the latest.
Ver: 3798   Respuesta: 1
Feature Request
John Sirois
Actualizado 2026-02-10 05:56:14 UTC
John
Ver: 3576   Respuesta: 1
Supported Hardware
Colin Brierley
Actualizado 2026-02-12 06:13:48 UTC
Ver: 4051   Respuesta: 1
Support email- No reply
Actualizado 2026-02-21 16:06:19 UTC
Ver: 3854   Respuesta: 2
RKR Home
Actualizado 2026-03-03 03:32:35 UTC
Ver: 3689   Respuesta: 1
New whisperer
Actualizado 2026-03-03 08:20:29 UTC
Bought a new whisperer as an old one is no longer working.
REMARK : WHILE I LIVE IN A TEMPERATE AREA NONE OF MY WHISPERERS LASTS MORE THAN 26 MONTHS WHICH IS SURPRISING AS IT IS NOT SUPPOSED TO BE A CONSUMABLE.
Clicked as required first blinking blue light then blinking white light.
Went to sensors and see the dead old one, the working one but do not see the newly bought one.
Do not see either a + sign to add a new one.
What should I do ?
Ver: 3636   Respuesta: 1
Monkeyzu
Actualizado 2026-03-12 08:20:45 UTC
Ver: 3615   Respuesta: 1
Seeding mode
John Sirois
Actualizado 2026-03-15 04:23:37 UTC
Ver: 3662   Respuesta: 1
Adding a 2nd system
Jayden Lockley
Actualizado 2026-03-21 07:03:33 UTC
I currently have a Netro Sprite system set up on a bore, I'm only using 9 stations currently but I can't easily add any more stations/wiring to this system.
I can easily access the wiring where I would like to add more stations, am I able to pick up the earth and pump start wires, and add a 2nd sprite or spark controller there?
Or has anyone got any ideas of how I can add more stations without running more wiring back to the master controller?
Ver: 3690   Respuesta: 1
Drip
Tim P
Actualizado 2026-03-22 18:03:43 UTC
All the zones work except I do not have any water coming out of the drip heads
Ver: 3343   Respuesta: 1
Drip
Tim P
Actualizado 2026-03-22 18:03:51 UTC
Ver: 3372   Respuesta: 1
Drip
Tim P
Actualizado 2026-03-22 18:23:10 UTC
Ver: 3324   Respuesta: 1
Pixie se desconecta
Lino
Actualizado 2026-03-22 19:30:16 UTC
Por qué se desconecta después de unos minutos mi unidad Pixie si tiene batería?
Ver: 3440   Respuesta: 1
Combine 2 zones
Alexis Demosthenous
Actualizado 2026-04-07 03:33:14 UTC
Hello everyone,
For my lawn i have 2 watering zones, is there a way to "force" schedule to combine those 2 zones to always follow each other? I dont want to water half my lawn on Monday and the other half on Thursday.
Ver: 3370   Respuesta: 2
Any way for user to open and replace battery in Whisperer 2?
Actualizado 2026-04-09 02:24:02 UTC
Any way for end user to open and replace battery on a whisperer 2?  It is out of warranty.
Ver: 3405   Respuesta: 1
Multiple locations
paul.robinson@bigbend.net
Actualizado 2026-04-12 21:06:55 UTC
