Irrigation
Antonio Cordon Rodriguez
Actualizado 2026-05-21 19:28:42 UTC
Ver: 4029   Respuesta: 2
sprite not using correct weather data
Douglas Peale
Actualizado 2026-05-26 06:47:02 UTC
I have a home weather station that feeds data to https://www.wunderground.com/dashboard/pws/KCASANJO507?cm_ven=localwx_pwsdash
I have my sprite pointed at my specific weather station on wundergound.com. Today, my sprite claims I had 0.02" of rain, but my weather station detected none, and wunderground.com says I had no rain.
I have been noticing for a while that Netro was showing different rain data from what my weather station recorded, Netro usually records more rain than I actually got. I suspect this may be why my oranges are always under sized.
Somehow Netro is getting the wrong infromation from wunderground.com. Is there any way to fix this?
Ver: 2517   Respuesta: 1
wunderground
Nino Guzzo
Actualizado 2026-05-28 17:35:15 UTC
I can't register my weather station ID in the Netro app. Can anyone help me? Thanks.
Ver: 2634   Respuesta: 1
Rain forecast
Riccardo!!
Actualizado 2026-05-31 15:34:34 UTC
Hi, I have a Spark controller. Where can I find in the app the rainfall forecast for next days?
In the home page I can see only humidity, temperature and wind but not rain in mm.
Riccardo
Ver: 2406   Respuesta: 1
Massmo Tommasi
Actualizado 2026-06-06 13:21:26 UTC
grazie
Ver: 2281   Respuesta: 1
How do I save my password
Ruth Wengert
Actualizado 2026-06-09 16:33:16 UTC
I doubt if someone’s gonna break in and change my sprinkler time how in the hell do I save my password to this thing? I don’t wanna have to remember to put it in every time I want to change my sprinklers.
Ver: 2536   Respuesta: 1
Cannot connect to my WiFi
Actualizado 2026-06-10 02:59:45 UTC
Tried several times following with the instructions. And failed!? And my system was operational and my App was disabled for no apparent reasons!?
Ver: 2326   Respuesta: 2
Anne M
Actualizado 2026-06-10 22:39:31 UTC
For test purposes, I have my Whisperer 2 in a terra cotta flowerpot that is very dry.  It always reads that the moisture is very high.  I have a Pixie at the house faucet.  I reset the Whisperer and it did not help.  What's wrong?
Ver: 2387   Respuesta: 1
Più elettro valvole
Enrico Crola
Actualizado 2026-06-11 08:07:24 UTC
Come faccio per poter attivare in una zona più elettrovalvola contemporaneamente??
Ver: 2380   Respuesta: 1
Can you add rain sensor to the Spark system? Is there one available?
Devros
Actualizado 2026-06-12 00:03:03 UTC
Just wondering if you can add a rain sensor to the Spark system?  If so what brand?
Ver: 2467   Respuesta: 1
Notificaciones
Peter urrielu
Actualizado 2026-06-14 07:59:40 UTC
Hola, en la sección de notificaciones de la aplicación, no hay nada, no hay ningún tipo de notificaciones para elegir. Es un problema de la versión de la aplicación o es un problema mío?. Gracias
Ver: 2606   Respuesta: 1
Nuovo wi fi e luce spenta
Paolo Grippa
Actualizado 2026-06-21 08:13:39 UTC
A seguito di nuova installazione wi fi fibra home, il dispositivo mi da luce spenta come se non arrivasse corrente, ma in realtà la corrente arriva. Ho infatti provato a staccare e riattaccare tutto ma la situazione non cambia. Quale può essere il problema?
Ver: 2247   Respuesta: 1
How does eco factor work?
Actualizado 2026-06-21 16:02:22 UTC
Ver: 2292   Respuesta: 1
Netro Skill
ghutch2262
Actualizado 2026-06-26 14:52:07 UTC
The netro skill does not stay connected to Alexa.  What is the issue with that?
Ver: 2325   Respuesta: 1
No water coming from sprinklers of 3 zones
Sukesh Arora
Actualizado 2026-06-28 15:23:05 UTC
Although the App says that it is watering a particular zone but no water comes out of the sprinkler heads. What could be causing that?
Ver: 2210   Respuesta: 1
Sukesh Arora
Actualizado 2026-06-28 15:31:51 UTC
Netro Smart Settings
caravagg
Actualizado 2026-06-30 11:58:32 UTC
netro smart settings, please rank relative seasonal water use from high to low for the different settings: EPA, Boost, New Plant, Deep, Frequent, Regular, ECO
Ver: 2231   Respuesta: 1
Wrong location detected: Italy address is always converted to Oklahoma, USA
tizzy
Actualizado 2026-07-02 10:11:39 UTC
I have a Netro Spark 8 controller installed in Italy.
My address is:
Via Gonfalone 49
73031 Alessano (LE)
Italy
However, Netro always changes my location to:
  • ZIP code: 73032
  • State: OK
  • Country: United States
Because of this, the weather forecast is completely wrong and Smart Watering is using incorrect weather data.
I cannot edit the ZIP code, state or country, either in the Android app or on the web interface.
Could you please help me fix my location or update your geolocation database?
Ver: 2194   Respuesta: 1
Controller
rodrigo6760
Actualizado 2026-07-10 12:33:26 UTC
Cómo puedo borrar un controller que aparece en la app y que ahora ya no está funcionando ? Aparece fuera de línea y no puedo borrarlo.
Muchas gracias
Ver: 2232   Respuesta: 1
Help!!!!
Sylvie Giacinti Vincent
Actualizado 2026-07-12 05:23:08 UTC
My husband suddenly die !! I don t understand nothing with Netro because he used to manage it on his phone
How can I join some one in France to explain me how can I use it now  I am totally list and désespérate
Please help me 😢😢
Ver: 2247   Respuesta: 0
