Help!!!!
Sylvie Giacinti Vincent
Actualizado 2026-07-12 05:23:45 UTC
My husband suddenly die !! I don t understand nothing with Netro because he used to manage it on his phone
How can I join some one in France to explain me how can I use it now  I am totally list and désespérate
Please help me 😢😢
Ver: 2125   Respuesta: 1
Using Netro Watering on Polyglot 3x
Peter Henneberry
Actualizado 2026-07-12 17:13:10 UTC
Anyone using the universal devices polyglot plugin for Netro version 0.1.18
In the configuration it states to use my serial number from the Netro Spark which I see on the Netro app but when I add it and click save, Polyglot says it is an invalid serial number
Ver: 2065   Respuesta: 0
Pixie
Magnus Swenson
Actualizado 2026-07-12 18:45:13 UTC
Can you add external choice vs plants ; this device can actually have multiple use like pool filler timer etc thank you ! Pixie 1 solar hose timer
Ver: 2207   Respuesta: 2
Pixie and smart water sensor
Thomas Lamb
Actualizado 2026-07-26 12:29:27 UTC
Is there any way to use the smart plant sensor gen 2 with my pixie?
Ver: 1977   Respuesta: 1
Soil Moisture Readings
dougt425
Actualizado 2026-08-06 16:06:01 UTC
I currently have several Netro Whisperer 2 sensors and receive moisture, temp and solar readings. But i also have other soil sensors - e.g., Ecowitt. The two sensors appear to measure soil moisture on different scales. Can someone - from Netro - explain to me clearly how the Whisperer measures moisture and how I should interpret different readings in the same bed (e.g., Ecowitt measures 28%, Whisperer measures 96%).
Ver: 1921   Respuesta: 1
Purchasing a moisture sensor
Gyade B.
Actualizado 2026-08-09 15:34:55 UTC
How do I purchase a Netro Controller moisture sensor?
Ver: 2368   Respuesta: 1
Valves Not Opening
Micky Boles
Actualizado 2026-08-09 21:16:47 UTC
Netro controller has run fine for 3 or 4 years. Trouble arose overnight. Controller is connected to my WiFi and no lights blinking,  it if I do, say, a manual run, it sends the command to the controller, and the app thinks it is running water, but the valves aren't opening. Have tried to do this with multiple valves, have reconnected to WiFi, etc but can't make it open valves. Ideas?
Ver: 1958   Respuesta: 1
Whisperer 2
Joan Garrell
Actualizado 2026-08-13 09:03:11 UTC
Ver: 2258   Respuesta: 1
Joel Braunstein
Actualizado 2026-08-14 20:04:32 UTC
Ver: 1850   Respuesta: 1
Smart watering isn’t working
Weikang Chen
Actualizado 2026-08-21 00:17:31 UTC
I have 2 problems with the Netro this year.
1. The weather auto detect to rain to skip the water session doesn’t work.   No matter how low the threshold I set to, it doesn’t skip the water day when it rains.  I have it set to .1 inch now.
2. When I set to delay the watering , it doesn’t reschedule the schedule.   It just continue with the watering.
My system has been watering while it’s pouring outside so many times and wasted so much money on my water bill because this app screwed up so bad.
Is there a the fix to my problems?
Ver: 1792   Respuesta: 1
May 31, July 31, Aug 31 restriction
Dave H
Actualizado 2026-08-25 22:13:52 UTC
Can the app be configured to not run on my May 31, July 31 and Aug 31 restrictions? How? I can't figure it out
Ver: 1732   Respuesta: 1
Shut off at 2 mn
jsolis
Actualizado 2026-08-26 22:17:41 UTC
Each zone started shutting off after 2mn when doing a manual run. The system has been working for 3 yrs.
Ver: 1775   Respuesta: 1
Shut off at 2 mn
jsolis
Actualizado 2026-08-26 22:17:56 UTC
Ver: 1698   Respuesta: 0
Offline and “connecting”
Miguel Camarillo
Actualizado 2026-08-29 14:11:05 UTC
My netro sprite shows a green light on but remains offline in the app. When I try and run a sprinkler it shows “connecting” and the sprinkler never comes on. I’ve tried unplugging it, resetting, and ensured everything is properly wired. My internet connection is also strong and stable. It has worked perfectly for the past 6 months until now. I purchased it in February of this year.
Please help I’m out of ideas.
Ver: 1706   Respuesta: 0
Whisper 2 88% to 34% in 30 mins?
Actualizado 2026-09-01 12:43:37 UTC
I have a zone that keeps overwatering. It has erratic shifts in water percentage, usually occurring after the zone is watered. This results in the zone then coming back on again and running for an extremely long period of time (extra water cycle). I would hate to think that the sensor is bad again, as I’ve had this one replaced twice in the last year. I tried moving the location of it, of course, tried resetting the learning on it, but it is a recurrent situation.
Also kind of goofy we cannot attach photos…
Ver: 1585   Respuesta: 0
Dark Mode- Font Size
Actualizado 2026-09-01 12:47:57 UTC
[I posted a request for an update on this feature request submitted and confirmed for the roadmap back in 2022 but had no reply after two months so starting new thread]
Ver: 1597   Respuesta: 1
Mike Carey
Actualizado 2026-09-04 14:18:00 UTC
Ver: 1636   Respuesta: 2
Internet reconnection issue
Gianluca T
Actualizado 2026-09-17 19:39:14 UTC
hi,
everytime the power goes off and come back on, the wifi router take longer than the netro sprite to restart. it looks like netro try to connect to the internet just once (or at least only before the router is back online). the result is that every time the power goes off and come back on netro sprite can't connect to the internet and i have to manually switch it off and on after the router is back online. This is becoming a big issue, is there a patch to this? the Netro Sprite needs to try to connect again and again at least every hour. better if every 10 minutes.
please let me known.
best regards
Ver: 1357   Respuesta: 1
John Jessee
Actualizado 2026-09-18 18:53:08 UTC
Just read about this new app.  It shows exaclty how kuch rain fell on an exact location.  Not rehional or local weather station.  Can this link to this app to turn off watering when it rains
Ver: 1416   Respuesta: 1
App keeps requiring password reset
Rockhead413
Actualizado 2026-09-18 23:02:56 UTC
  • App keeps requiring password
Ver: 1418   Respuesta: 1
