Lives in: Washington, NC, US
Using: SPARK-16 , WHISPERER-2
Growing: Centipede, Hydrangea
Questions
Support email- No reply
30
Updated at 2026-02-21 16:06:19 UTC
Topic: Smart Watering
30
Updated at 2025-07-10 18:58:03 UTC
Kirk
Font size/ dark mode
30
Updated at 2025-06-28 04:53:19 UTC
Topic: Connected Home
30
Updated at 2025-06-25 16:41:56 UTC
30
Updated at 2025-06-18 03:59:06 UTC
30
Updated at 2025-05-16 12:40:39 UTC
30
Updated at 2023-05-14 12:23:35 UTC
Topic: Troubleshooting
Kirk
Help! Pump Relay Question
30
Updated at 2022-09-01 13:43:25 UTC
Topic: Installation
My unit has been working great . However, the relay no longer trips when a zone is activated. Am I supposed to have 24v A/C between M and C (on the right side of the panel, not the zone side) when a zone is active? I can trip the relay if I pull it from the Netro. Some sort of voltage output map would be helpful.
I have new grass seed down, so please help soon.
Weather Underground
30
Updated at 2022-08-03 13:52:50 UTC
Much appreciated
Kirk
Dark mode/ font update?
30
Updated at 2022-08-03 13:48:59 UTC
Dark Mode and/ or Font size
30
Updated at 2022-06-30 23:05:11 UTC
on my iPhone it is nearly impossible to read a lot of the characters because they aren’t in dark black letters it’s a very light thin font. It seems like it would be a lot easier to read if the application supported dark mode. The other option would be to set a preference to increase the font size. That seems like pretty standard request so I’m hoping you guys might be able to get it in a future build.
30
Updated at 2019-09-17 12:12:15 UTC
30
Updated at 2019-08-16 02:54:33 UTC
Promise Made- Promise KEPT!
30
Updated at 2019-08-03 04:32:30 UTC
Where's our promised update?
30
Updated at 2019-07-31 11:19:38 UTC
30
Updated at 2019-06-14 11:23:21 UTC
Topic: Netro App
Weather Company API- Revenue stream for Netro
30
Updated at 2019-04-20 12:58:20 UTC
It is my understanding that you could restore our ability to pull data into netro from our individual weather stations. This would require paying for the API, which you could mark up 20% and offer a paid option to netro clients. $3.99 a year, for example, would be totally worth it to get accurate information to my sprinkler controller. As I have outlined in a previous post, dark sky has proven to be wildly inaccurate. It's Miss estimates rainfall by at least 50%, on average, and is within three degrees plus or minus on high temperature only about 50% of the time.
30
Updated at 2019-04-20 12:21:46 UTC
Topic: Netro App
Mr Bad Example
