Whisperer Changing Colors
Patrick
更新時間 2020-05-06 02:32:37 UTC
My Netro Whisperer sensor LED changed colors from blue to red on its own.  Is this normal?
瀏覽: 4477   回覆: 1
Sprite app says its watering but it is not
Jen Morgan
更新時間 2020-05-03 18:02:31 UTC
It has been working for 3 weeks, but now it does not.
I have checked all 7 zones. No wiring issues. Has proper voltage.
It just won't come on. How do I get it to work again. This is a new unit. Sprinklers are all fine and had a tune up when the Sprite was installed.
I have unplugged it and plugged it back in. I need help soon, I have new sod and many new plants in my yard and gardens.
瀏覽: 4467   回覆: 1
Sprinklers don’t work
Richard Mundy
更新時間 2020-05-02 18:59:26 UTC
Please help
瀏覽: 4758   回覆: 1
Carlo Monico
更新時間 2020-04-26 06:59:36 UTC
Grazie.
瀏覽: 4364   回覆: 1
Plant Sensor
Ntenaive
更新時間 2020-04-25 21:56:51 UTC
瀏覽: 4832   回覆: 2
Gian Piero Pepino
更新時間 2020-04-25 09:23:06 UTC
Gian Piero
瀏覽: 4449   回覆: 1
Best sync option?
jbart65
更新時間 2020-04-22 02:56:17 UTC
瀏覽: 4514   回覆: 1
google home not connected
maxtrash
更新時間 2020-04-21 23:01:57 UTC
what could be going on?
瀏覽: 4437   回覆: 2
Keep Connected option
jbart65
更新時間 2020-04-17 17:38:10 UTC
The particulars:
瀏覽: 4490   回覆: 1
Which Alexa app?
jbart65
更新時間 2020-04-16 20:00:55 UTC
Jeffry
瀏覽: 4518   回覆: 1
Netro app on google home
Danilo
更新時間 2020-04-11 10:07:58 UTC
Thanks for your support.
瀏覽: 4402   回覆: 1
Settings
Massimo Povolo
更新時間 2020-04-07 06:31:48 UTC
瀏覽: 5044   回覆: 5
Home Assistant integration
Casey S
更新時間 2020-04-05 19:46:53 UTC
瀏覽: 4972   回覆: 2
duerson
更新時間 2020-03-27 20:59:20 UTC
瀏覽: 4618   回覆: 1
Delivering term please
yodiego
更新時間 2020-03-14 18:08:21 UTC
瀏覽: 4277   回覆: 1
alexa & pixie
stefano banfi gaslini
更新時間 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
瀏覽: 4449   回覆: 1
更新時間 2020-02-28 07:49:20 UTC
瀏覽: 6719   評論: 3
Changing ownership of home
Dario Sindicich
更新時間 2020-02-14 01:48:40 UTC
瀏覽: 5239   回覆: 2
Robert Bayes
更新時間 2020-02-07 03:39:19 UTC
瀏覽: 4219   回覆: 1
Introducing the Referral Program
更新時間 2019-12-10 03:02:22 UTC
To the Netro community:
We are pleased to launch the Netro Referral Program. You can earn reward points when your friends become Netro customers!
1.Invite your friends to join Netro using your unique link
2.Your friends get a discount or reward points
Your friends enjoy 10% off their first orders or $10 credits toward their first subscriptions.
3.Get your reward points and repeat to earn more
You will earn reward points* equivalent in value to the discounts or credits given to your friends.
*Reward points: for every US dollar your friends spend on their first orders you will earn 10 points ($0.1). You will earn 1000 points ($10) for every friend who chooses to subscribe. There are 3 ways to redeem the reward points:
1. Use the reward points to purchase Netro products at netrohome.com (100 points = 1 US dollar)
2. Use the reward points to pay for your subscription fee at netrohome.com (100 points = 1 US dollar)
3. Withdraw the reward points to your PayPal account (200 points = 1 US dollar)
Your reward points will never expire.
You can check more info about Netro's Referral Program here https://netrohome.com/shop/refer
瀏覽: 5558   回覆: 2
