Schedule stopped working
更新時間 2021-06-04 20:37:36 UTC
瀏覽: 4380   回覆: 1
Sensor inputs
更新時間 2021-06-01 11:33:16 UTC
瀏覽: 4225   回覆: 1
Sign it
Matthew Gruen
更新時間 2021-06-01 00:50:47 UTC
瀏覽: 4138   回覆: 1
Completely ater
更新時間 2021-05-31 20:03:22 UTC
瀏覽: 4140   回覆: 1
Pixie displays Soil Moisture reading without any sensor
Michael Host
更新時間 2021-05-11 03:07:21 UTC
Hi.  My Pixie shows a Soil Moisture reading that changes over time, but it doesn’t have a Whisperer connected to it.  It seems to influence the watering frequency.  When I look at the watering schedule, it’s supposed to water every nine days, but instead it’s watering every three days.  Is this normal?
瀏覽: 3992   回覆: 1
Whats the difference between Forecast and Expectation
Julio Perez
更新時間 2021-05-09 16:43:52 UTC
I was looking on the preference section and see that we can select one of this. By default come with expectation selected. Wich is better?
瀏覽: 3850   回覆: 1
Just checking
Momma & Papa Behr
更新時間 2021-05-03 12:53:18 UTC
I wondered if there are any Metro Omaha Landscaping Companies on this forum.
瀏覽: 3986   回覆: 0
Whisperer in the UK
Marlpit
更新時間 2021-05-02 23:16:04 UTC
Really liking the Netro Pixie, keen to pick up the whisperer. How do i get one in the UK. Shipping from the states is expensive?
Will the Pixie work with the Whisperer without needing a bridge?
瀏覽: 4213   回覆: 1
Scheduled Runs not turning on but app shows they ran
Dakota Haeffner
更新時間 2021-05-02 17:04:53 UTC
My app is showing scheduled runs for morning and nights that I set up using a repeating program. At the time they are supposed to run they just saying loading the entire time. After they don’t run I can do a manual run through the app and it works fine. Any suggestions?
瀏覽: 3938   回覆: 1
Any promotion codes/discounts available?
更新時間 2021-05-01 18:03:02 UTC
Looking to purchase a couple of whisperer sensors, and can’t really justify the $60 price.  Any discount codes/discount for multiples available?  Any money back guarantee if not satisfied with the whisperer?
Also,  how many people are using advanced smart water feature that allow the controller totally decide when to water.  I have set it up but cringe at the runtimes and days running in the calendar, and keep reverting back to my schedule.  Seems like it would be using a lot more water.
瀏覽: 4369   回覆: 1
Run Off Adjustment?
Carey Family
更新時間 2021-04-26 03:28:07 UTC
Hi Netro, I have fruit trees in clays soils and I have the whisper sensor helping me monitor the water. I have two issues right now. One is the sensor does not seem to detach much change in the moisture content in the soil, even immediately after an hour of watering. The other issue is I am getting run off during each watering cycle but I cant figure out how to spread out the watering or reduce them without going to a manual setting. Can you help me? Thank you!
瀏覽: 4236   回覆: 1
Can not connect to wifi
Andrei Stancovici
更新時間 2021-04-25 18:30:25 UTC
Hello. I have restarted my netro 16 after winter. First it connected ok and after a power lose i stopped connecting to wifi. I have tried everything. The light is solid as if is connected. Plese help. Thank you
瀏覽: 3806   回覆: 1
Trigger a single zone based on zwave switch
Moe E
更新時間 2021-04-22 14:54:46 UTC
My pools water fill line is connected as a zone on my sprinkler system. I would like to trigger turning on and off a zone based on a zwave switch status. Can this be done, or should I return my netro for a different system? It looks like netro does not have api access, and IFTTT is extremely limited. Thanks
瀏覽: 4087   回覆: 1
Zones
dougbrandes
更新時間 2021-04-22 12:34:57 UTC
I only have 2 zones.  1st zone is programmed for only 2 days per week while the 2nd zone is programmed everyday and at a different time then the first zone.  However on the 2 days the first zone comes on, the second zone does not despite be programmed to.  As mentioned the on times are completely different.
瀏覽: 3873   回覆: 1
Jason
更新時間 2021-04-20 21:49:32 UTC
瀏覽: 3866   回覆: 1
Can’t start Netro
Joe Horner
更新時間 2021-04-05 14:47:49 UTC
I have a good WiFi signal.
瀏覽: 3956   回覆: 1
No power to controller
Barbara Williams
更新時間 2021-03-23 16:10:05 UTC
Our controller has been working fine, and we had to replace some solenoids that were faulty. The controller is plugged into a verified live socket but no lights turn on. I can't hook up wifi, and it appears to be dead.
瀏覽: 4178   回覆: 1
App non si configura con IPHONE 7 Plus iOS 14.4
Antonino Marretta
更新時間 2021-03-08 08:10:40 UTC
Salve a tutti, come da titolo la app durante la configurazione con smartphone in questo caso un IPHONE 7 PLUS con iOS 14.4 non riesce a completare l’accoppiamento con Netro , ho riprovato con smartphone Android con successo.
Ho fatto presente l’anomalia anche all’azienda costruttrice, la quale ci sta lavorando.
Chiedo a qualcuno di voi se ha avuto lo stesso problema.
瀏覽: 3696   回覆: 1
Ignoring Restrictions for one zone
Brodie Lewis
更新時間 2021-03-01 02:55:53 UTC
Hey Team,
Have one zone that is connected to drippers in an undercover area with hanging baskets
Need to set a regular schedule for watering in this area, that ignores restrictions for this area, but still applies for other zones.
Is this available in the app at the moment?
瀏覽: 4054   回覆: 1
How many electro valves
javyto98
更新時間 2021-02-25 21:52:58 UTC
Hello I would like to know how many electro valves I can open at the same time?
瀏覽: 3901   回覆: 1
