WiFi link
Benedetto
更新時間 2021-02-20 17:56:18 UTC
Hi, i would appreciate if someone could help me. I need to link the netro to the router without password, however the procedure need a password in any case: how can I do? Thanks for the support
瀏覽: 3994   回覆: 1
Turning off
Rony Z
更新時間 2021-02-15 13:58:39 UTC
瀏覽: 4201   回覆: 1
Cancel
Awilda Betancourt
更新時間 2021-01-24 13:09:23 UTC
瀏覽: 4165   回覆: 1
MAC address
John Conley
更新時間 2021-01-07 15:26:26 UTC
瀏覽: 4160   回覆: 1
Darren Cassar
更新時間 2021-01-05 11:03:18 UTC
Darren
瀏覽: 4235   回覆: 1
Pixie Valve Issue
Alec Simonson
更新時間 2020-12-15 05:48:10 UTC
Alec
瀏覽: 4709   回覆: 2
Battery dead
Arthur
更新時間 2020-12-07 22:00:27 UTC
瀏覽: 4397   回覆: 1
Haris Eliades
更新時間 2020-11-25 06:25:20 UTC
Haris
瀏覽: 4454   回覆: 3
Jens Wymeersch
更新時間 2020-11-17 13:25:17 UTC
Dear,
Thank you so much,
Jens
瀏覽: 4866   回覆: 2
Offline buy watered
Haris Eliades
更新時間 2020-11-09 06:22:11 UTC
瀏覽: 4352   回覆: 1
Curt Lizzi
更新時間 2020-11-03 18:41:08 UTC
Am I doing something wrong?
Curt
瀏覽: 4563   回覆: 1
dinzdale
更新時間 2020-11-03 16:00:28 UTC
瀏覽: 4278   回覆: 1
How do I turn off for Winter?
Paul A
更新時間 2020-10-30 20:59:47 UTC
瀏覽: 4169   回覆: 2
New user
Haris Eliades
更新時間 2020-10-28 20:35:38 UTC
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
瀏覽: 4242   回覆: 1
David Farries
更新時間 2020-10-24 20:24:40 UTC
瀏覽: 4500   回覆: 1
Problem With application
Alex Guerrero
更新時間 2020-10-17 08:21:08 UTC
瀏覽: 4248   回覆: 1
How stop 1 day
Leonardo Antonucci
更新時間 2020-10-11 18:33:55 UTC
瀏覽: 4220   回覆: 1
OFFLINE
Javier López-Guerrero
更新時間 2020-10-03 08:20:26 UTC
Help!
Javier
瀏覽: 4178   回覆: 2
Controller LED Light
Texas AF
更新時間 2020-09-22 14:01:57 UTC
瀏覽: 4193   回覆: 1
IFTTT - Watering Schedule
更新時間 2020-09-10 05:56:28 UTC
Thanks in advance,
瀏覽: 4481   回覆: 1
