Kevin Westling
更新時間 2021-03-28 06:40:48 UTC
瀏覽: 6805   回覆: 1
When will be Netro Smart available in Europe?
Raúl Vázquez-Noguerol Méndez
更新時間 2021-03-20 20:38:05 UTC
I’d like to know if Netro Spark will be available in Europe.
瀏覽: 6515   回覆: 1
What does the app show for whisperer?
Growbro
更新時間 2021-03-17 20:54:48 UTC
I am trying to figure out what the graph shows for the week. It seems like the app shows the average light for the day. Moisture present at midnight each day. And average temperature each day. Is this correct? Or is it maximum temperature for the day?
It would be nice if I could have the graph could show more than just one reading per day. It would also be nice if you could go back and see the more detailed chart for a full day after it has passed. As it is now I can only see the one data point for days that are past.
Finally for the individual days it is a bit annoying switching between am and pm. I wish there was just a graph for each day that looked like the graph for the week/month except that there was a data point for every hour. Definitely more annoying and less useful to have am and pm separate and not be able to see the changes like you can with the graph.
瀏覽: 6662   回覆: 1
Foreca as weather provider
Fran Roman
更新時間 2021-03-09 21:21:35 UTC
Please add Foreca as weather provider! In Europe is much better than the available options on the app. Metro group is also a good option for your European customers like me.
瀏覽: 6626   回覆: 1
Zone says Loading
deleted_20260815225307_Gale
更新時間 2021-02-24 14:03:11 UTC
After the numerous power outages in Dallas last week, my sprinklers attempted to run this morning.   At its scheduled time, the zone shows "loading" but - no water.   ???
瀏覽: 6474   回覆: 1
Smart Watering Algorithm
更新時間 2021-02-09 13:52:56 UTC
瀏覽: 7382   回覆: 1
Date Format
Brian Keenan
更新時間 2021-01-29 09:00:07 UTC
瀏覽: 6553   回覆: 1
Geron R
更新時間 2021-01-19 23:06:52 UTC
Please advise
瀏覽: 7060   回覆: 1
Metro France cloud down?
Julian Hansen
更新時間 2020-12-29 01:07:40 UTC
瀏覽: 7308   回覆: 1
Roman Stanek
更新時間 2020-12-27 18:34:40 UTC
瀏覽: 6539   回覆: 1
App stuck on Idle
Pam Manwaring
更新時間 2020-11-18 02:21:16 UTC
瀏覽: 6630   回覆: 1
Stan Balafas
更新時間 2020-11-16 17:52:28 UTC
Thank ypu
瀏覽: 6716   回覆: 1
Add zones manually in queue
Haris Eliades
更新時間 2020-11-03 04:04:49 UTC
瀏覽: 7051   回覆: 1
"Next in" shows "--"
Luis Aguilar
更新時間 2020-10-14 18:45:01 UTC
瀏覽: 6765   回覆: 1
Questions about Netro app
Luis Aguilar
更新時間 2020-10-11 17:47:55 UTC
瀏覽: 6947   回覆: 1
Simone Nolletti
更新時間 2020-10-11 11:46:06 UTC
Buonasera,
瀏覽: 7419   回覆: 1
Switch Off automatically
Carlos Jimenez
更新時間 2020-10-09 20:18:31 UTC
I found two cases,
瀏覽: 6788   回覆: 1
Atif Khan
更新時間 2020-10-01 14:21:57 UTC
瀏覽: 6695   回覆: 1
Simple on/off
gmcg1984
更新時間 2020-09-17 01:54:35 UTC
瀏覽: 6759   回覆: 1
Start time change
Franco Storato
更新時間 2020-09-16 06:00:59 UTC
Thank you in advance,
Franco
瀏覽: 6566   回覆: 1
