Network error
Al Piscopo
更新時間 2021-06-17 10:27:03 UTC
瀏覽: 6236   回覆: 1
Watering adjustment settings
Lyndon Whyatt
更新時間 2021-06-15 16:55:38 UTC
瀏覽: 7053   回覆: 2
Text overlap in App
Kevin Westling
更新時間 2021-06-12 14:46:02 UTC
瀏覽: 6789   回覆: 1
Looking for Beta testers
更新時間 2021-06-11 06:11:28 UTC
Dear all Netro customers,
The long waited new version (3.0.0) of the Netro app is on the horizon. The major improvements of this version are
1. faster in loading data
2. new manual run interface
3. new home view design
4. more languages supported
We sincerely invite you to join the Beta testing program. Please email to support@netrohome.com or leave a message below if you would like to try the new app. Any feedback would be greatly appreciated !
Netro App Team
瀏覽: 31576   評論: 60
更新時間 2021-06-10 05:30:31 UTC
瀏覽: 6931   回覆: 1
Network Error With Code: 3404
Ian Meyer
更新時間 2021-06-08 16:16:25 UTC
瀏覽: 6963   回覆: 1
Pause a location\device
Jon Storch
更新時間 2021-06-06 23:08:20 UTC
-Jon Storch
瀏覽: 6902   回覆: 1
Manual Watering
Kevin Westling
更新時間 2021-06-04 00:42:16 UTC
瀏覽: 6862   回覆: 1
sal.jamil@me.com
更新時間 2021-06-02 12:11:24 UTC
瀏覽: 6523   回覆: 1
60 minute limit
C S
更新時間 2021-06-01 21:33:39 UTC
瀏覽: 6426   回覆: 1
Yuriy Andamasov
更新時間 2021-05-31 19:44:41 UTC
Thanks in advance.
瀏覽: 6690   回覆: 1
Pedro Abad
更新時間 2021-05-30 08:33:28 UTC
Thank you all!
瀏覽: 6992   回覆: 2
Douglas Peale
更新時間 2021-05-27 22:32:59 UTC
瀏覽: 6882   回覆: 1
banaszar
更新時間 2021-05-25 17:23:58 UTC
瀏覽: 6503   回覆: 2
Brad Grizzly
更新時間 2021-05-23 03:42:20 UTC
瀏覽: 6403   回覆: 1
bad wireless?
amagalla
更新時間 2021-05-19 16:50:44 UTC
Tony
瀏覽: 6963   回覆: 1
amagalla
更新時間 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
瀏覽: 7741   回覆: 2
Whisperer connexion
更新時間 2021-05-19 14:52:55 UTC
瀏覽: 7839   回覆: 2
Turning off wayer
更新時間 2021-05-16 21:29:12 UTC
瀏覽: 7395   回覆: 2
Seed watering
Adrian Azzopardi
更新時間 2021-05-16 10:18:05 UTC
瀏覽: 6669   回覆: 1
