RKR Home
更新時間 2026-03-03 03:32:35 UTC
瀏覽: 3093   回覆: 1
Supported Hardware
Colin Brierley
更新時間 2026-02-12 06:13:48 UTC
瀏覽: 3484   回覆: 1
Feature Request
John Sirois
更新時間 2026-02-10 05:56:14 UTC
John
瀏覽: 3024   回覆: 1
Notification
Alexis Demosthenous
更新時間 2026-02-05 19:28:19 UTC
瀏覽: 3204   回覆: 1
Shane V
更新時間 2026-01-19 04:54:45 UTC
瀏覽: 3217   回覆: 1
Giardino
Nelu Iftime
更新時間 2025-10-20 08:18:25 UTC
Sistemato
瀏覽: 5212   評論: 0
Can't login
更新時間 2025-10-13 15:40:38 UTC
This morning we noticed that my Sprite light was flashing. I tried to get into the app and it kept saying network error. I booted the Sprite, I booted my router, and the light is no longer flashing.
But when I try to log into the app now it says network error. I logged into metrohome.com and my Sprite was able to work from naturalhome.com, but I am still not able to log in to the app. I use the same login at netrohome.com as I did with my app.
瀏覽: 4758   評論: 1
Password
Ignacio Sánchez
更新時間 2025-09-26 11:38:52 UTC
瀏覽: 4561   回覆: 1
Info function
Giuseppe
更新時間 2025-09-20 09:48:50 UTC
瀏覽: 5126   回覆: 1
Time
Silvano Scotto
更新時間 2025-09-10 23:18:59 UTC
瀏覽: 5853   回覆: 1
Francesco Gritti
更新時間 2025-08-29 16:39:06 UTC
瀏覽: 6511   回覆: 1
help Netro Spark 6
Andrea Giannelli
更新時間 2025-08-14 09:03:33 UTC
Hi everyone,
Despite these attempts, the problem persists.
Thenks
瀏覽: 6621   回覆: 1
Change zone order
Matt Ward
更新時間 2025-07-22 00:43:18 UTC
瀏覽: 7331   回覆: 1
Whisperer low battery alert
Jesus Sanguinetti
更新時間 2025-07-19 15:24:34 UTC
瀏覽: 7066   回覆: 1
Pause
Tamgar chan
更新時間 2025-07-19 10:59:15 UTC
瀏覽: 6973   回覆: 1
Spark 8 zones
Jesus Laso
更新時間 2025-07-10 13:05:31 UTC
Good afternoon,
Thais in advance
瀏覽: 7083   回覆: 1
Sensors missing
dano
更新時間 2025-07-06 00:06:15 UTC
Dan
瀏覽: 7073   回覆: 1
Gyade B.
更新時間 2025-07-03 23:32:35 UTC
瀏覽: 7016   回覆: 1
Wifi error
nvenezia
更新時間 2025-07-02 14:51:10 UTC
瀏覽: 7009   回覆: 2
Unified controllers
Gianluca Spada
更新時間 2025-06-29 20:59:51 UTC
瀏覽: 6725   回覆: 1
