Bob Cohen
更新時間 2024-04-15 23:49:36 UTC
瀏覽: 7802   回覆: 2
Exclamation on Schedule
Oilol
更新時間 2024-04-10 12:56:31 UTC
Thanks in Advance!
Tim
瀏覽: 7599   回覆: 1
2 whisperer to 1 pixie
Paolo S
更新時間 2024-04-02 20:28:39 UTC
瀏覽: 8065   回覆: 1
Forecast doesn't show
Edan Manos
更新時間 2024-03-31 05:34:57 UTC
瀏覽: 7539   回覆: 1
Manual Operation
Mario Hardy
更新時間 2024-03-21 12:47:06 UTC
瀏覽: 7868   回覆: 1
Multiple watering a day
Phil Rubin
更新時間 2024-02-17 04:33:52 UTC
I need to run watering programs 2-3 times in a day, every day. I have "two fra m es" checked but it only will do one.  What do I  need to do?
瀏覽: 8016   回覆: 2
Pump
Carmelo Anaya
更新時間 2024-02-12 20:44:48 UTC
I have 6 zones but only 4 require to switch on the pump. How can I switch the pump individually on each zone?
瀏覽: 7586   回覆: 1
Port 1883 is blocked by the touter
Gary Harpley
更新時間 2024-02-10 05:49:13 UTC
Hi. Im a new user and everytning seems to be working ss it should but i get the following message when i check the server status
瀏覽: 7562   回覆: 1
Weather Underground
Gary Harpley
更新時間 2024-02-06 06:06:14 UTC
Hi. The app wont let me add my wundergound id number (IWAGGA24). Can you please help
瀏覽: 7566   回覆: 1
Data records
David Lrx
更新時間 2024-02-03 12:14:57 UTC
Is it possible to upload data from the app so I can keep record on an externat file for more than a month ?
I would like to keep record for a year long.
David.
瀏覽: 7558   回覆: 1
Manual run times need to be longer and editable while running
Richard
更新時間 2024-01-19 21:27:13 UTC
Hi Netro,
One frustration I have is that manual run times are important to me but cannot be longer than 1 hour (or programs) and cannot be adjusted while running.
I have Netro connected to a solenoid that controls watering of our small vineyard.
I rarely water in any way other than manual, because I need to control the amount of watering and also use fertigation to feed the vines.
Due to the amount of water required, I need between two to three hours of watering. I also like to adjust as I go, depending on how long the fertigation takes, so the ability to increase time without stopping the watering is also important.
My other solution is to disconnect the wire from Netro and use a Shelly 1 instead, whereby I can turn the watering on and off as I desire.
I would rather just use the Netro app, given that everything is already connected.
It is quite limiting to not allow hours as well as minutes (or to allow more than 60 minutes). amd not to be able to increase (or decrease) the time while the manual run is going.
瀏覽: 8591   回覆: 2
PM Time
Cacho
更新時間 2024-01-01 15:43:35 UTC
Hello again, i found that i can set night times on the webpage, and it get sets on the app after that.   But if i try from the app i cannot set any night times.
瀏覽: 7746   回覆: 1
Stand alone Whisperer 2 Sensor
suddath
更新時間 2023-12-30 17:56:29 UTC
We have a Netro Pixie that we have been using to water trees in our backyard.
We purchased two Whisperer 2 sensors to help understand how much to water.
We paired and installed one sensor which is linked to the Pixie.  This sensor works well and reports light, moisture and temperature and appears in the app in the zone watered by our Pixie.
The other sensor installed as "standalone".  This sensor does not show up on our app including in settings.
How do we access this "standalone" sensor or data?
thank you.
瀏覽: 7892   回覆: 1
Pixie & Wisper 2 - How to get them to connect?
Mark Smith
更新時間 2023-12-08 08:15:08 UTC
I have purchased 3x Wisper 2s and 3x Pixies as well as a Spark. I want to set the watering frequency based on information from the Whispers. In the app, it has a sensor field, but it's not selected. I can't find any instructions on getting them to work together. I opened a ticket with support 2 days ago but no response.
瀏覽: 8468   回覆: 2
Home Assistant integration
Homestead One
更新時間 2023-12-01 14:54:03 UTC
Hi guys,
Is it possible to integrate nestro smart sprinkler to home assistant?
Thx!
瀏覽: 8061   回覆: 1
Meaning of Pie-Chart Illustration in Sensor Graph
Mark
更新時間 2023-11-16 08:54:15 UTC
Hi there, Ive noticed that some of the pie-slices in the moisture/temperature/lux graphs from my Whisperer Plant Sensors are heavily coloured (darker) and some are lightly coloured (lighter). Is this supposed to indicate something?
I suspected that maybe the difference in colour reflects upload as either live (or cached), but I double checked and they all have >50% wifi connection strength and report regularly...
瀏覽: 7917   回覆: 1
更新時間 2023-11-07 06:09:05 UTC
Then you should put Sprite in "paused" mode just in case some one (for example the kids) accidentally starts a manually run from the app. To put Sprite in "paused" mode, you can go to the Home page->"Enabled".
瀏覽: 14898   評論: 1
PROGRAMS. "NOTES" FIELD
Javier NM
更新時間 2023-11-02 07:49:07 UTC
I am using Netro software with a Sprite-6 controller. After some moths use I am delighted with the system. The tools it provides help me a lot controlling my garden, with good results. Congratulations. Normaly I use three out of my four zones in Smart (advanced) mode, and the fourth one in Smart (Basic).
I would be useful if we could have a field (name it "Notes" or similar) so that we could enter useful information about the use of each individual program (for example, "I reduced frecuency to alternate days after Oct 15th", or other information.
Not having that field causes useful feedback not to be available when managing programs.
瀏覽: 8274   回覆: 1
Sprite 12 Controller Problem
John LaRocca
更新時間 2023-10-14 01:42:23 UTC
瀏覽: 7768   回覆: 1
Hub with more than 1 timers
Kay Fluhr
更新時間 2023-10-08 07:46:18 UTC
Dear netro team
I solved the problem.
瀏覽: 7927   回覆: 1
