Replace controller
paul.robinson@bigbend.net
更新時間 2024-08-24 22:53:15 UTC
瀏覽: 7467   回覆: 1
problematiche app
Giampaolo Mariani
更新時間 2024-08-20 08:16:25 UTC
瀏覽: 7473   回覆: 1
Boost factor in app
Jorge Castrillo
更新時間 2024-07-30 13:55:17 UTC
瀏覽: 7599   回覆: 1
Manual watering beta
Lynn johnson
更新時間 2024-07-10 04:17:16 UTC
瀏覽: 7581   回覆: 1
Increase Run Time Per Zone
Don Carli
更新時間 2024-07-04 18:58:45 UTC
Don
瀏覽: 7874   回覆: 2
Steve M
更新時間 2024-06-30 23:53:31 UTC
瀏覽: 7446   回覆: 1
Adjusting for tree cover
Steve M
更新時間 2024-06-30 23:47:30 UTC
瀏覽: 7405   回覆: 1
app crashing
Christoforos
更新時間 2024-06-28 14:13:56 UTC
Can you please help.
Christoforos
瀏覽: 7428   回覆: 1
Where is the documentation on how to use the app?
Lance Blaise
更新時間 2024-06-20 03:41:17 UTC
Where is the documentation on how to use the app? I have no clue how to set my own schedule or how to use the smart scheduling... I can't find anything on how to use this app at all and it's pretty confusing. I am looking at the app and it seems to have smart watering enabled, but there are times where it's skipping 3 days randomly and there is no rain that is supposed to take place on those days, so no clue why it's skipping those days. Can someone direct me to where the documentation is for using the app?  Thank you.
瀏覽: 7444   回覆: 1
network error
更新時間 2024-06-18 10:24:07 UTC
i have a Netro app
on ios with a 12 station
Starting this morning i receive a
Network error message
i restarted/ re connect
same message
May i need a new firmware ?
瀏覽: 8320   回覆: 3
Change whisperer mode
Jure
更新時間 2024-06-15 11:33:22 UTC
What is the proper way for changing Whisperer from standalone mode to adding it to my Netro Pixie or Sprite?
瀏覽: 7522   回覆: 1
Where to see Whisperer data collected in the Netro App ?
JDo REY
更新時間 2024-06-07 09:01:29 UTC
Where to see Whisperer data collected in the Netro ?
瀏覽: 7552   回覆: 2
Rainbird R Van rotator
更新時間 2024-06-04 19:09:06 UTC
Hi there
瀏覽: 8045   回覆: 3
Shut off one zone
Wil
更新時間 2024-05-31 04:05:40 UTC
瀏覽: 7658   回覆: 2
Javier NM
更新時間 2024-05-26 06:32:56 UTC
瀏覽: 7974   回覆: 1
PREFERRED ARTICLES
Javier NM
更新時間 2024-05-12 06:36:42 UTC
瀏覽: 8085   回覆: 1
Help!
John Zuzula
更新時間 2024-05-02 14:46:09 UTC
瀏覽: 7757   回覆: 1
Manual operation doesn’t stop
Ciro Bracciante
更新時間 2024-04-29 11:31:14 UTC
瀏覽: 7379   回覆: 1
App Netro
Antonio Cordon Rodriguez
更新時間 2024-04-28 09:28:48 UTC
瀏覽: 7412   回覆: 0
Fabio F
更新時間 2024-04-20 14:28:45 UTC
 How do I solve this problem?
瀏覽: 8244   回覆: 4
