Programs transfer to a new device
Giacomo
更新時間 2026-09-22 12:08:53 UTC
The day before yesterday my 12-zone Sprite died after 7 years of loyal service; I was hoping it was the AC power adapter, but the multimeter says everything is OK. I ordered a new Spark on Amazon, and my question is whether I can transfer the programs to the new device or if they are tied to the old one.
Thanks in advance for your replies
瀏覽: 442   回覆: 1
Dark Mode- Font Size
更新時間 2026-09-01 12:47:57 UTC
[I posted a request for an update on this feature request submitted and confirmed for the roadmap back in 2022 but had no reply after two months so starting new thread]
瀏覽: 737   回覆: 1
May 31, July 31, Aug 31 restriction
Dave H
更新時間 2026-08-25 22:13:52 UTC
Can the app be configured to not run on my May 31, July 31 and Aug 31 restrictions? How? I can't figure it out
瀏覽: 851   回覆: 1
Soil Moisture Readings
dougt425
更新時間 2026-08-06 16:06:01 UTC
I currently have several Netro Whisperer 2 sensors and receive moisture, temp and solar readings. But i also have other soil sensors - e.g., Ecowitt. The two sensors appear to measure soil moisture on different scales. Can someone - from Netro - explain to me clearly how the Whisperer measures moisture and how I should interpret different readings in the same bed (e.g., Ecowitt measures 28%, Whisperer measures 96%).
瀏覽: 1205   回覆: 1
Candice Wang
更新時間 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
瀏覽: 8152   評論: 0
Controller
rodrigo6760
更新時間 2026-07-10 12:33:26 UTC
Cómo puedo borrar un controller que aparece en la app y que ahora ya no está funcionando ? Aparece fuera de línea y no puedo borrarlo.
Muchas gracias
瀏覽: 1460   回覆: 1
Notificaciones
Peter urrielu
更新時間 2026-06-14 07:59:40 UTC
Hola, en la sección de notificaciones de la aplicación, no hay nada, no hay ningún tipo de notificaciones para elegir. Es un problema de la versión de la aplicación o es un problema mío?. Gracias
瀏覽: 1927   回覆: 1
Massmo Tommasi
更新時間 2026-06-06 13:21:26 UTC
grazie
瀏覽: 1648   回覆: 1
Irrigation
Antonio Cordon Rodriguez
更新時間 2026-05-21 19:28:42 UTC
瀏覽: 3364   回覆: 2
Greenhouse zone
Ivan G
更新時間 2026-05-20 08:59:47 UTC
瀏覽: 3332   回覆: 1
New feature request
更新時間 2026-05-10 19:34:04 UTC
瀏覽: 1964   回覆: 1
programs - status sign
Lee Hill
更新時間 2026-05-08 06:45:32 UTC
Developers, can you add some indication to list of programs to see which is enabled, which is not?
Instead of going into each and scroll to the very bottom to check 'enabled'.
I think of either being grayed out or adding a sign, whatever simplest may work.
thank you
瀏覽: 1965   回覆: 1
programs - reordering
Lee Hill
更新時間 2026-05-08 06:40:14 UTC
瀏覽: 2004   回覆: 1
Notifications sur Android
Cyrille ROBINET
更新時間 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
瀏覽: 2047   回覆: 1
enable switch
Andrew McNaughtan
更新時間 2026-04-19 22:32:06 UTC
I switched the enable switch in the Netro app to disable and now I can't get it to turn back on. The app says "next run not scheduled". When I close the app and reopen it, the switch has moved back to the disabled position. Nothing works, I can't even manually water. The controller has a green light showing and I have tried powering the controller off and back on and it reconnects without an issue but the app will not work.
瀏覽: 2655   回覆: 1
Multiple locations
paul.robinson@bigbend.net
更新時間 2026-04-12 21:06:55 UTC
瀏覽: 2729   回覆: 1
Combine 2 zones
Alexis Demosthenous
更新時間 2026-04-07 03:33:14 UTC
Hello everyone,
For my lawn i have 2 watering zones, is there a way to "force" schedule to combine those 2 zones to always follow each other? I dont want to water half my lawn on Monday and the other half on Thursday.
瀏覽: 2781   回覆: 2
Will
更新時間 2026-03-17 21:54:57 UTC
瀏覽: 3749   回覆: 3
Seeding mode
John Sirois
更新時間 2026-03-15 04:23:37 UTC
瀏覽: 3044   回覆: 1
Monkeyzu
更新時間 2026-03-12 08:20:45 UTC
瀏覽: 2993   回覆: 1
