Strange watering cycle
Joe Mariano
更新時間 2023-05-22 14:40:16 UTC
瀏覽: 7723   回覆: 1
Mismatch zones/times
Jose R
更新時間 2023-05-21 12:40:53 UTC
So happy with how this works.
瀏覽: 7406   回覆: 1
Richard Nibbler
更新時間 2023-05-17 02:50:09 UTC
Tyvm
瀏覽: 8094   回覆: 3
Whisperer wifi connection
Jim Shields
更新時間 2023-05-15 21:20:33 UTC
瀏覽: 7469   回覆: 1
Paolo S
更新時間 2023-05-12 15:41:24 UTC
Any suggestion?
Any issue with iphone 14?
瀏覽: 7843   回覆: 1
Alvaro Guardado
更新時間 2023-05-08 18:25:58 UTC
Dear support,
瀏覽: 7343   回覆: 1
Francesco Zorzetto
更新時間 2023-05-05 23:09:14 UTC
瀏覽: 7619   回覆: 1
Suggestion
Tom Carn
更新時間 2023-05-01 17:01:12 UTC
瀏覽: 7309   回覆: 1
How to cancel schedule
Wayne Curdy
更新時間 2023-04-27 01:15:38 UTC
瀏覽: 7333   回覆: 1
0 Minute Zones?
Stephen Wyatt
更新時間 2023-04-26 12:59:02 UTC
瀏覽: 7202   回覆: 1
Add user Error
更新時間 2023-04-21 09:26:43 UTC
瀏覽: 7322   回覆: 2
Wasteful
David Maerzke
更新時間 2023-04-13 13:19:47 UTC
瀏覽: 7471   回覆: 1
Abraio
更新時間 2023-04-10 17:53:48 UTC
瀏覽: 7411   回覆: 1
更新時間 2023-04-10 15:17:46 UTC
Hi there
- seed type
- watering adjustement - EPA
- how tall to cut the grass
瀏覽: 8123   回覆: 1
Michael Cayless
更新時間 2023-04-02 21:21:01 UTC
瀏覽: 7849   回覆: 1
Vincent Pollinzi
更新時間 2023-03-30 22:43:53 UTC
瀏覽: 7351   回覆: 1
Daily Backup of System
Zsolt Karman
更新時間 2023-03-20 08:35:47 UTC
Hi Team,
Regards, Zsolt
瀏覽: 9503   評論: 2
Feature request
更新時間 2023-03-15 12:51:04 UTC
瀏覽: 8146   回覆: 2
更新時間 2023-03-15 08:50:34 UTC
瀏覽: 8008   回覆: 1
Scheduled for March watering says next watering April
Texas AF
更新時間 2023-03-03 14:31:32 UTC
This is so damn frustrating to use.
I set to water every odd day.  Start in March.  It’s March 3rd no watering being done and the app says next watering April.
Any suggestions?   Been struggling with this app for two years now about to give up
瀏覽: 7607   回覆: 1
