Brett Lilly
更新時間 2020-04-13 18:42:28 UTC
瀏覽: 7381   回覆: 1
Resetting Netro Whisperer
Patrick
更新時間 2020-04-09 19:34:52 UTC
瀏覽: 8886   回覆: 1
Irrigation time striketrough
Luca Manfrin
更新時間 2020-04-07 12:34:22 UTC
thank you
瀏覽: 7416   回覆: 1
Luca Manfrin
更新時間 2020-04-07 10:07:29 UTC
-SKIP FOR TODAY
瀏覽: 7353   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:22:40 UTC
瀏覽: 7648   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:19:37 UTC
瀏覽: 7626   回覆: 1
Run Netro in one zone now
Stan Bumgarner
更新時間 2020-03-28 20:15:35 UTC
Stan
瀏覽: 6985   回覆: 1
2 or more zone at same time
Mirko Paganelli
更新時間 2020-03-28 15:32:05 UTC
瀏覽: 7414   回覆: 1
J H
更新時間 2020-03-24 21:16:47 UTC
瀏覽: 6952   回覆: 1
App Crashes on adding product
Tarudro
更新時間 2020-02-24 20:24:10 UTC
I just received my Pixie and Whisperer and wanted to set them up using my iPhone.
Therefore I launch the app and go to "Add Product", select the Pixie and then I'm promted to enter my location and a name for the timer.
When I click on "next" the app crashes and returns to the home screen. 100% reproducible. I tried to enter different adress and name, but couldn't make it work. Crashes every time.
Reinstall also didn't solve the problem.
Netro App: 2.4.0
iPhone 11 Pro
iOS 13.3.1
German (also tried English)
Let me know, if you need anything else to reproduce/solve this issue or if there is something that I could do to prevent it.
So far, I couldn't find anything in the forum here.
BR Lukas
PS. I just tried also on my iPad Air 2 - same crash.
瀏覽: 14841   回覆: 4
Soil Types
Tim Foster
更新時間 2019-12-14 13:28:44 UTC
The app asks me to define my soil type and gives me a small list to choose from. I'm no gardening expert by any means and so I'm not really sure I've got this right. I selected the most draining type based on nothing more that guesswork really. We're in Yucatán, México so the entire area is limestone rock, but this website (https://sites.google.com/site/soilsoftheyucatanpeninsula/soil-types) gives more detail about the soil types in Yucatán. All this has done though is confuse me more.
Is there any reliable way that I can determine my soil type in Netro? The website says it's likely to be one (or a combination) of Gleysols, Histosols, Vertisols, Solonchaks, Leptosols, and Cambisols
瀏覽: 7532   回覆: 1
Can't add new managers
Tim Foster
更新時間 2019-12-03 20:00:25 UTC
瀏覽: 7587   回覆: 1
Smart zone enabled
Steve Kalani
更新時間 2019-11-25 18:36:19 UTC
瀏覽: 7155   回覆: 1
Schedule setup
Rich Christenson
更新時間 2019-09-21 14:51:31 UTC
瀏覽: 7603   回覆: 1
Unit measurements
Homestead One
更新時間 2019-09-17 20:29:09 UTC
瀏覽: 7539   回覆: 1
Feature request
Tony D.
更新時間 2019-09-12 20:32:30 UTC
Tony
瀏覽: 8097   回覆: 1
Manual run time screen
Rich Christenson
更新時間 2019-09-06 10:25:49 UTC
瀏覽: 8015   回覆: 1
Weather Provider
Martin Müller-Zantop
更新時間 2019-08-22 10:57:44 UTC
Can you please explain to me the big difference of the next watering days using different weather providers? As you can see in my print screens the data of temperature and humidity are nearly the same. With one provider next watering cycle will be in 2 days and with another in 11 days.
Thank you for your comments
Martin
瀏覽: 8452   回覆: 2
One day restriction
Lou Infeld
更新時間 2019-08-12 21:49:14 UTC
瀏覽: 7597   回覆: 1
Update application
Anyhony Harwood
更新時間 2019-08-11 11:58:55 UTC
瀏覽: 7265   回覆: 1
