Schedule screen
Dick Milde
更新時間 2022-05-30 14:02:03 UTC
瀏覽: 6334   回覆: 1
Setting up the schedule
Sasha Obradovic
更新時間 2022-05-30 22:11:58 UTC
I’m trying to setup schedule for watering for next five months, But watering schedule shows only for two next months. I check the settings and I do have a selected five next month. is there something I’m not doing right?
瀏覽: 8715   回覆: 2
Andy Ricco
更新時間 2022-05-31 06:12:27 UTC
瀏覽: 8678   回覆: 1
Zone
Bertin Grégory
更新時間 2022-05-31 15:50:10 UTC
Bonjour
Serait-il possible d’activer 2 zones en même temps réfléchi
瀏覽: 9554   回覆: 2
Why is there no on/off
Eric Berndt
更新時間 2022-06-01 19:01:43 UTC
瀏覽: 7378   回覆: 2
Eric Berndt
更新時間 2022-06-01 19:02:18 UTC
瀏覽: 7099   回覆: 0
Eric Berndt
更新時間 2022-06-01 19:03:43 UTC
瀏覽: 7302   回覆: 1
PWS invalid
Giovanni Franceschini
更新時間 2022-06-01 19:16:43 UTC
Please enter a valid ID !
ISANREMO24
Thanks Giovanni
瀏覽: 7789   回覆: 1
Reset rain delay to 0 (null)
Bruce Abbott
更新時間 2022-06-02 22:18:21 UTC
瀏覽: 7446   回覆: 1
Sid Smith
更新時間 2022-06-02 22:21:42 UTC
瀏覽: 7499   回覆: 1
Move a Zone between Terminals
Gian Piero Pepino
更新時間 2022-06-03 12:13:40 UTC
Hello.
Is it possible to move a Zone, in my case: "Prato e back giardino" from Terminal 2 to Terminal 3 in a efficient way?
Let's say, for instance:  Copy Zone "Prato e back giardino" or Move "Prato e back giardino" from Terminal2 to Terminal 3, without being obliged to cancel the previous and reprogram all in a new Zone?
I've a problem with Terminal 2: the wire broke inside and I am not able to remove it ....
Thanx a lot
Gian Piero
瀏覽: 9185   回覆: 1
Kurt H
更新時間 2022-06-03 20:40:34 UTC
瀏覽: 7727   回覆: 1
Simon Clark
更新時間 2022-06-04 07:26:36 UTC
瀏覽: 7715   回覆: 2
Jeff W
更新時間 2022-06-04 12:43:04 UTC
瀏覽: 7450   回覆: 1
Matt Smith
更新時間 2022-06-04 19:01:43 UTC
瀏覽: 7209   回覆: 1
James Berg
更新時間 2022-06-05 01:03:46 UTC
瀏覽: 8654   回覆: 1
Minimum moisture content
Jason Pappas
更新時間 2022-06-05 03:34:37 UTC
瀏覽: 7113   回覆: 1
Sid Smith
更新時間 2022-06-06 21:47:14 UTC
瀏覽: 7309   回覆: 5
Netro light
beppezhome
更新時間 2022-06-09 14:46:24 UTC
瀏覽: 8069   回覆: 1
Jen Morgan
更新時間 2022-06-10 10:56:50 UTC
瀏覽: 6739   回覆: 2
