App crash
Jiang Zheyue
更新時間 2022-04-14 14:34:05 UTC
瀏覽: 6905   回覆: 1
Scott Gustafson
更新時間 2022-04-14 22:26:18 UTC
瀏覽: 8455   回覆: 1
idpitt
更新時間 2022-04-16 13:50:17 UTC
What am I missing?
瀏覽: 6888   回覆: 1
Watering days
更新時間 2022-04-16 18:22:19 UTC
Home display is correct and shows Last watering the day before at the date and time in the program (watering planned everyday) but under Discover many days are shown as if there has not been any irrigation.
What could be the reason why ?
瀏覽: 8544   回覆: 2
Feature Request
Tod Johnson
更新時間 2022-04-16 18:22:20 UTC
瀏覽: 6163   回覆: 1
Gaspare Miceli
更新時間 2022-04-18 06:23:55 UTC
瀏覽: 10812   回覆: 1
Alessandro Malaguti
更新時間 2022-04-18 10:04:06 UTC
I attach mp4 link
瀏覽: 5999   回覆: 1
Wifi connection
更新時間 2022-04-18 11:31:15 UTC
瀏覽: 6927   回覆: 1
Netro lose wifi connection
Rob Rossi
更新時間 2022-04-19 09:22:12 UTC
If I restart the router,
how can it be solved?
瀏覽: 6346   回覆: 1
John Lillistone
更新時間 2022-04-19 11:26:49 UTC
瀏覽: 7696   回覆: 1
Davide M.
更新時間 2022-04-20 09:23:18 UTC
Good day all,
Thanks for help.
Davide
瀏覽: 6844   回覆: 1
ITA Translation
Davide M.
更新時間 2022-04-20 07:21:19 UTC
Hi all,
Best Regards,
Davide
瀏覽: 6646   回覆: 1
Blinking light on my Netro
RMeador
更新時間 2022-04-21 01:20:07 UTC
瀏覽: 5972   回覆: 1
doppia irrigazione
mauro croce
更新時間 2022-04-22 10:52:27 UTC
瀏覽: 8226   回覆: 1
Whisper Sensor
Ian Moore
更新時間 2022-04-26 02:55:10 UTC
瀏覽: 8224   回覆: 1
Brian Brun
更新時間 2022-04-26 04:23:12 UTC
瀏覽: 6675   回覆: 1
Calendar won’t update
Yuanchao X
更新時間 2022-04-26 19:44:49 UTC
瀏覽: 6175   回覆: 2
J H
更新時間 2022-04-26 20:17:38 UTC
瀏覽: 6380   回覆: 1
Activity not showing on ap
Mark Killeen
更新時間 2022-04-27 15:21:38 UTC
瀏覽: 6777   回覆: 1
Netro Whisperer
Fabrice GOUFFRAN
更新時間 2022-04-28 12:29:53 UTC
I am unable to have my new whisperer working. It doesn’t light on even after half a day under the sun.
瀏覽: 8775   回覆: 1
