更新時間 2022-06-19 17:14:35 UTC
Added information:
瀏覽: 10386   回覆: 4
Wunderground
Joachim Hogg
更新時間 2022-06-18 05:08:25 UTC
IDTSCHLO2
Thanks a lot
瀏覽: 6263   回覆: 1
更新時間 2022-06-19 07:58:52 UTC
瀏覽: 8803   回覆: 1
更新時間 2022-06-19 18:52:23 UTC
瀏覽: 7150   回覆: 1
Spark zones do not work
justjeff1972
更新時間 2022-06-20 13:51:18 UTC
I installed my Spark yesterday and zones 5 through 8 do not work. I metered the valve on zone 5 and it is fine. I also swapped zones 4 and 5 and the fault stayed on 5. I tried connecting the zone to 6 and 8 and still received the fault. Is the controller defective?
瀏覽: 8548   回覆: 2
Chronological order irrigation
Alex78
更新時間 2022-06-20 20:00:26 UTC
Good morning.  How do you put the zones in chronological order, starting zone 1 first and so on.thank you
瀏覽: 8583   回覆: 2
Sun Rise
更新時間 2022-06-20 20:36:54 UTC
瀏覽: 8473   回覆: 1
Moisture level %
Haris Eliades
更新時間 2022-06-22 08:48:45 UTC
Hello!
瀏覽: 6825   回覆: 1
2 Spark 16s linked?
Jim Simmons
更新時間 2022-06-22 14:56:08 UTC
I've installed 2 Spark 16s to control a 26 valve system.  All the valves are working fine with this setup.  Are there instructions for the best way to configure this?  I have low water pressure and can't run 2 valves at the same time, so some synchronization between the 2 Sparks is needed.  I could manually setup restrictions on each unit, so they can't overlap, but that seems too coarse.  Any ideas about the best way to program this?
瀏覽: 7501   回覆: 2
Change manual run back
Jack Davis
更新時間 2022-06-24 05:10:45 UTC
瀏覽: 6935   回覆: 1
New Whisperer Issue
Alfonso Marin Salgueiro
更新時間 2022-06-24 15:15:07 UTC
Hello everyone from Spain.
Can somebody help me?
I attach a photo.
Thank you very much.
瀏覽: 8174   回覆: 1
awall
更新時間 2022-06-27 13:10:28 UTC
瀏覽: 6302   回覆: 1
Weather accuracy
Rafael Lliso
更新時間 2022-06-27 17:31:02 UTC
Rafa
瀏覽: 8560   回覆: 2
Pump Problem
wvfox
更新時間 2022-06-28 16:18:58 UTC
Vance
瀏覽: 7982   回覆: 1
pe ti
更新時間 2022-06-29 14:34:04 UTC
瀏覽: 7669   回覆: 1
Val Smith
更新時間 2022-06-30 23:51:43 UTC
瀏覽: 7997   回覆: 0
Val Smith
更新時間 2022-06-30 23:50:46 UTC
瀏覽: 6463   回覆: 0
Jeff W
更新時間 2022-06-30 17:16:24 UTC
瀏覽: 6547   回覆: 1
Dark Mode and/ or Font size
更新時間 2022-06-30 23:05:11 UTC
on my iPhone it is nearly impossible to read a lot of the characters because they aren’t in dark black letters it’s a very light thin font. It seems like it would be a lot easier to read if the application supported dark mode. The other option would be to set a preference to increase the font size. That seems like pretty standard request so I’m hoping you guys might be able to get it in a future build.
瀏覽: 8979   回覆: 1
longer historic data
更新時間 2022-07-02 07:50:45 UTC
瀏覽: 7070   回覆: 1
