Watering during a restriction
Valeria Dp
Actualizado 2022-09-20 20:26:21 UTC
Tonight at 2.30 my netro start to watering. I had to stop it starting a manual program and stop it because in the app there was no watering sign.
Then I put a restriction for 3 days and around noon netro starts to watering again. There was a lost wifi signal for a minute cause by a voltage drop.
Is it normal?
Ver: 8201   Respuesta: 1
Ananth
Actualizado 2022-09-21 12:25:49 UTC
 How do i change this?
lot of water being wasted.
Ananth Bandla
Ver: 8046   Respuesta: 2
Sprite-6
Rockhead413
Actualizado 2022-09-26 18:04:30 UTC
Vincent Devlahovich
Ver: 8316   Respuesta: 1
Irrigation program,
Rosario Russo
Actualizado 2022-09-27 10:58:58 UTC
Rosario
Ver: 8045   Respuesta: 1
Rosario Russo
Actualizado 2022-09-27 11:06:57 UTC
Ver: 6793   Respuesta: 1
Rick Miller
Actualizado 2022-09-29 23:49:53 UTC
Ver: 6811   Respuesta: 1
Veronica Slaughter
Actualizado 2022-10-01 05:11:02 UTC
Any insight is so welcome!
Ver: 6934   Respuesta: 1
Discover and weather accuracy
Geron R
Actualizado 2022-10-01 12:38:37 UTC
Ver: 7109   Respuesta: 1
No connection to WiFi.
Gianluca De Virgilio
Actualizado 2022-10-02 21:48:54 UTC
Good afternoon.
Ver: 8002   Respuesta: 2
Main feeder line shutoff valve control
Richard Miles
Actualizado 2022-10-10 02:16:36 UTC
My main water line to the sprinkler system came loose and flooded my vacation home yard with 250,000 gallons of water before the leak was discovered and repaired.  Does Netro have the ability to control an electric valve on this feeder line such that the main valve will only open when the irrigation system calls for water?
Ver: 8164   Respuesta: 1
Weather station
Actualizado 2022-10-14 02:07:16 UTC
Ver: 7534   Respuesta: 1
Water pressure
Omer Zadikevitch
Actualizado 2022-10-18 18:15:38 UTC
Ver: 6766   Respuesta: 1
Actualizado 2022-10-20 14:57:19 UTC
Thanks for your advice
Ver: 7072   Respuesta: 1
Water valve opened
Paolo Talamelli
Actualizado 2022-10-23 10:52:29 UTC
Ver: 7966   Respuesta: 1
Cutrone
Actualizado 2022-10-25 17:06:24 UTC
Hello all!
Ver: 7909   Respuesta: 2
Daniel Gajardo
Actualizado 2022-10-27 01:22:57 UTC
Ver: 7179   Respuesta: 1
Percentage Adjustment
jeremyagrelius@gmail.com
Actualizado 2022-10-29 18:31:12 UTC
Ver: 6633   Respuesta: 1
LearNetro Whisperer
Actualizado 2022-10-30 19:15:38 UTC
At the end of the whisperer's learning time, the times are set automatically in the program or have to be done manually?
Ver: 9165   Respuesta: 2
Gianluca Bus
Actualizado 2022-11-03 12:03:59 UTC
Hi all!
Netro App vesion: 3.1.0
Netro controller hw ver.: 1.2
Thanks in advance.
Gianluca
Ver: 8008   Respuesta: 1
Carlo Drago
Actualizado 2022-11-04 18:48:50 UTC
Carlo
Ver: 8294   Respuesta: 1
