Green Peas
Actualizado 2023-01-01 18:34:14 UTC
Ver: 8119   Respuesta: 2
Home Assistant
Jens Wymeersch
Actualizado 2023-01-12 09:25:04 UTC
Ver: 9465   Respuesta: 2
Customized moisture level not triggering watering
Richard
Actualizado 2023-01-12 21:29:59 UTC
I have a Sprite with 3 Whisperers, all in the veggie patch.
I have the zones set to customize with a low of 25% and a high of 45% (I find 30 - 35 % moisture about right)
But the zones just won't get watered!
Zone 1 is down to 6% today and has been dropping steadily for days.
I HAVE to manually water, as the day time temperatures are consistently over 30 degrees (today 33, tomorrow 37).
Otherwise the plants will die.
Given there are only two values to enter (low and high). How do I stop the Netro from skipping days and putting the zones in the "Moisture" category??
Ver: 9548   Respuesta: 1
Change Username
Casa Luna
Actualizado 2023-01-13 10:08:35 UTC
Is it possible?
Thanks in advance :)
Ver: 7459   Respuesta: 1
Delay on Manual watering
Jim Barnes
Actualizado 2023-01-22 01:22:58 UTC
Why is it when I select a manual watering it delays until wake up?
Ver: 8031   Respuesta: 1
Reduce watering time in 1 zone
Ale Levi
Actualizado 2023-01-22 19:32:59 UTC
Hi, I'd like to reduce the watering time in 1 zone which gets dumped each time Netro waters. The other zones are ok. Is there a way to do that in the smart mode? Maybe set an offset for that specific zone?
Ver: 7564   Respuesta: 2
andrew58
Actualizado 2023-01-25 08:49:48 UTC
Ver: 7546   Respuesta: 1
Jim Barnes
Actualizado 2023-01-25 13:36:55 UTC
Please help!!!
Ver: 8149   Respuesta: 2
Whisperer plant sensor
Vincent Coutinho
Actualizado 2023-01-26 20:56:14 UTC
How do you find the sensor battery percentage on the netro app.
Ver: 8265   Respuesta: 1
Help
Vũ Trần
Actualizado 2023-01-30 07:35:09 UTC
Ver: 9654   Respuesta: 3
Whisperer light
Actualizado 2023-02-01 09:56:18 UTC
What should I do ?
Ver: 8303   Respuesta: 1
MEANING OF code E2
balvant patel
Actualizado 2023-02-02 16:06:49 UTC
What is E2 means?
Pl. reply ASAP
Patel
Ver: 7863   Respuesta: 1
Vanina Lesko
Actualizado 2023-02-03 09:47:24 UTC
Ver: 8089   Respuesta: 1
Smart schedules
Vincent Coutinho
Actualizado 2023-02-07 20:51:01 UTC
Ver: 8234   Respuesta: 1
Whispered sola panel deteriorated after 6 months
Actualizado 2023-02-08 06:15:54 UTC
After 6 months of whispere’s exposed to sun, the protective layer of screen is started yo be deteriorated, losing the transparency property and protection to UV, meaning is catching up less sun.
Answer from Netro support after several exchanges had not been at the right level, despite that last topic was really well addressed.
“Thanks for your info and it should not affect the normal use of the sensor. Please let us know if you see any further issues during use.“
Check pictures and make your statement, but I am not convince about quality of manufacturing of the whispered elements.
David
Ver: 8365   Respuesta: 1
Set watering days
Mel Culley
Actualizado 2023-02-12 02:31:35 UTC
I am struggling to set up the watering days
There isn’t an option for 4 / 3 / 4 rostered days which is are allocation here in Perth Australia
Please advise
TIA 👍
Ver: 10984   Respuesta: 2
Richard
Actualizado 2023-02-17 06:29:52 UTC
Hi there.
Cheers.
Ver: 8461   Respuesta: 2
Smart zone manual setup
Vieri Verze
Actualizado 2023-02-18 08:31:43 UTC
I do not understand how many millimeters to set. I have microsprinklers of 4lt/h and 2lt/h. I thought to set to 4000ml/h but the max is 100ml/h.
How to calculate? I have a big terrace with 30 plants and various microsprinklers.
Vieri
Ver: 8243   Respuesta: 2
Location Setting
ubo25
Actualizado 2023-02-18 10:10:44 UTC
Please advise how I can change the location. I am staying in Windhoek, Namibia.
Ver: 7662   Respuesta: 1
Notifications/Wunderground
Fernando AT
Actualizado 2023-02-26 18:00:46 UTC
Hello!
1. How can I enable notifications (when watering, sensor moisture level…)?
2. Cannot set my Wunderground station ISANTA605.
Ver: 7815   Respuesta: 1
