Scheduled for March watering says next watering April
Texas AF
Actualizado 2023-03-03 14:31:32 UTC
This is so damn frustrating to use.
I set to water every odd day.  Start in March.  It’s March 3rd no watering being done and the app says next watering April.
Any suggestions?   Been struggling with this app for two years now about to give up
Ver: 7811   Respuesta: 1
Shedule
jmgrau
Actualizado 2023-03-09 07:21:43 UTC
How can I program the app so that it does not do automatic shedule watering, only those programmed manually, I only want the gespa dalt and gespa baix dryers to irrigate 1 minute a day.
Ver: 7775   Respuesta: 1
Actualizado 2023-03-15 08:50:34 UTC
Ver: 8221   Respuesta: 1
Feature request
Actualizado 2023-03-15 12:51:04 UTC
Ver: 8382   Respuesta: 2
Whisperer is suddenly crazy
JM del Amo
Actualizado 2023-03-15 15:39:31 UTC
After a lot of time working fine, suddenly whisperer is crazy. With no reason suddenly the humidity is at "0" and the temperatures are above "90". I have cleaned with water the whispers. I have cleaned the device with water but remains doing same random mistake-
Ver: 7888   Respuesta: 1
Is Netro that smart?
Alessandro Alfei
Actualizado 2023-03-16 00:53:44 UTC
why if Netro is so smart after months of learning with the whisperer still uses the "humidity to add watering" data set by me and doesn't create a custom program?  smartzone is in advanced level and regular mode.
Ver: 8394   Respuesta: 2
Carlo Drago
Actualizado 2023-03-18 18:55:41 UTC
Waiting your kind reply
Carlo
Ver: 8099   Respuesta: 1
cannot connect my pixie to mi wifi with unifi Access point
christophe Minery
Actualizado 2023-03-24 18:42:53 UTC
Someone can help me to connect to my unifi Wifi tm sensor Pixie ?
All goes OK unitl last step.... when it tell me that I connect connect to it
thanks
Ver: 8496   Respuesta: 1
Dont't start manual irrigation
Simone Teressi
Actualizado 2023-03-26 11:39:57 UTC
I've checked that My netro isonline...but if i start a manual irrogation app say to me "communicating" and never begin to start..... If i turn off elecrticity and turn on again..... And then i go to manual  Irrogation and press start irrogation begin immediatly
Ver: 7849   Respuesta: 1
No 24V output?
Bigolin Davide
Actualizado 2023-03-26 16:15:24 UTC
What can I do?
Ver: 7634   Respuesta: 1
No wifi connection
gdimofte@gmail.com
Actualizado 2023-03-27 18:00:53 UTC
Dear Sir
Gabriel
Ver: 7620   Respuesta: 1
Sprinklers not going off per schedule
Brian Brun
Actualizado 2023-03-28 22:50:06 UTC
What are my sprinklers not going off per schedule? I have a schedule that it supposed to kick off Tuesday and Thursday. It is set to start at 6:00. It is 6:50 and it has not went off. I just had to manually run a cycle.
Ver: 8153   Respuesta: 1
Vincent Pollinzi
Actualizado 2023-03-30 22:43:53 UTC
Ver: 7569   Respuesta: 1
Michael Cayless
Actualizado 2023-04-02 21:21:01 UTC
Ver: 8060   Respuesta: 1
Phone number
Graham Corrett
Actualizado 2023-04-05 13:07:22 UTC
Does anyone I have a contact/help number for this company possibly in the UK I’ve sent an email but no response!
Ver: 7958   Respuesta: 1
Netro Sprite + Netro Pixie Z1
xergyo
Actualizado 2023-04-10 09:58:51 UTC
Is it possible to connect the Netro Pixie Z1 to the wifi and to the App using the Netro Sprite without the need for the Netro Hub?
Ver: 10260   Respuesta: 1
Pixie linked to 2 iphone
Paolo S
Actualizado 2023-04-10 13:29:30 UTC
Is it possible to control 1pixie with 2 iphone?
Ver: 8214   Respuesta: 1
Actualizado 2023-04-10 15:17:46 UTC
Hi there
- seed type
- watering adjustement - EPA
- how tall to cut the grass
Ver: 8353   Respuesta: 1
Abraio
Actualizado 2023-04-10 17:53:48 UTC
Ver: 7621   Respuesta: 1
Wiring multiple controllers
John Wright
Actualizado 2023-04-10 19:05:31 UTC
I have an existing 18 zones irrigation controller which I am replacing. I require 2 controllers. No master valve or pump.
It is possible to connect both commons to the existing common connected to the 18 zones?
Ver: 10307   Respuesta: 1
