Lives in: Alcobendas, Comunidad de Madrid, ES
Using: SPRITE-6 , WHISPERER , WHISPERER-2
Growing: Fraser Photinia, Tall Fescue
Questions
EPA watering
32
Updated at 2026-09-30 10:51:59 UTC
Topic: Connected Home
I want to save water in the long term , what is the best watering EPA or Deep. I want to set it up now the temperature has lowered and I want to boost the roots
New feature request
32
Updated at 2026-05-10 19:34:04 UTC
Topic: Netro App
Remote reboot of whisperer
32
Updated at 2025-08-17 14:48:38 UTC
Topic: Troubleshooting
Is there a way to remotely reboot a whisperer sensor?
I am on vacation adn one of the sensors is showing up weird values in all the parameters.
overwatering
32
Updated at 2025-05-20 12:55:43 UTC
Topic: Smart Watering
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
2 zones must run the same amount of time
32
Updated at 2024-07-06 15:35:53 UTC
Hi there
I have the garden zones like the diagram. And I want zone 4 a 3 run the same amount of time. Currently they use different whisperers and have different schedules what makes the grass to present in summer dry patches. I would like to force to run 3 and 4 the same amount of time.
Should I use only one whisperer attached to both zones (3 and 4)?
programs overlaping (smart scheduler and watering adjustment)
32
Updated at 2024-06-25 10:19:26 UTC
The smart schedule overlaps with the watering adjustment program that runs when the moisture goes below a %.
Yo can see here that zone 5 run 10 minutes the program and then 37 minutes the scheduler.  It has no sense and it is a waste of water.
  1. After the watering adjustment run, the smart scheduler should recalibrate the timing based on the humidity of the land.
  2. I have the whisperers, the whisperer should monitor the humidity and stop the smart watering once it reaches 99% of humidity but it seems the program runs all the way.
This could be improved in the application.
Thanks for your support and keep up the good job
Rainbird R Van rotator
32
Updated at 2024-06-04 19:09:06 UTC
Topic: Netro App
Hi there
Wifi password reset
32
Updated at 2024-04-29 06:27:43 UTC
Topic: Installation
I updated the wifi password in the router. I was able to set up the password in the netro controller but not in the whisperers. I followed the steps provided by the app, pressing 6 times very fast the whisperer button.
But the whisperer wifi did not appear. I tried with 2 of the 5 whisperer I have, but process is not working
Skip watering did not work
32
Updated at 2024-04-17 12:50:29 UTC
I have the whisperer to avoid watering over 40% humidity, but the system did not skip it
Moisture watering adjustment
32
Updated at 2024-01-09 20:27:04 UTC
Hi there I have one of the whisperer that doesn't allow to adjust watering below 50%,
Sensor number 2 in my installation.
All the rest I can chose lower values
Feature request update
32
Updated at 2023-07-25 06:11:19 UTC
Topic: Netro App
32
Updated at 2023-06-19 09:25:40 UTC
32
Updated at 2023-04-10 15:17:46 UTC
Topic: Netro App
Hi there
- seed type
- watering adjustement - EPA
- how tall to cut the grass
Feature request
32
Updated at 2023-03-15 12:51:04 UTC
Topic: Netro App
32
Updated at 2022-09-07 05:47:06 UTC
May you check it?
Whisperer too weak
32
Updated at 2022-08-19 21:10:55 UTC
Hi there
Update Feature
32
Updated at 2022-08-17 16:09:34 UTC
Topic: Netro App
Alfonso
32
Updated at 2022-06-19 07:58:52 UTC
Whisperers not sending data
32
Updated at 2022-03-18 12:17:29 UTC
Topic: Netro App
Disconnect irrigation
32
Updated at 2021-11-02 10:24:53 UTC
