Ken Laberteaux
Lives in: Ann Arbor, MI, US
Using: SPRITE-6
Questions
Default Smart Zone settings
21
Ken Laberteaux
Updated at 2021-09-17 00:51:11 UTC
Topic: Connected Home
Ken
21
Ken Laberteaux
Updated at 2021-06-22 04:16:23 UTC
Topic: Smart Watering
Water turned off
21
Ken Laberteaux
Updated at 2020-07-31 01:08:39 UTC
I had to turn off my water valve to my sprinkler system for a week (ending in a few days) and forgot to disable smart watering on my netro.  Netro thinks it did a complete watering last Saturday, and adjusted estimated soil moisture accordingly.  Netro isn't planning another watering for another 9-10 days.  However no watering last Saturday occurred.
How best should I handle this?  Is there a way to delete past watering, which will lower soil estimated moisture, triggering a sooner watering than currently scheduled?  Or should I just do a manual long watering as soon as I can?
