Lives in: Sudbury, MA, US
Using: PIXIE-1 , WHISPERER-1
Growing: Coleus, Pompon Dahlia
Questions
27
Updated at 2022-09-07 21:08:59 UTC
Topic: Netro App
Can Pixie measure water flow?
27
Updated at 2022-08-23 14:09:01 UTC
Topic: Smart Watering
27
Updated at 2022-08-21 09:13:22 UTC
Topic: Netro App
Why gap in smart schedule?
27
Updated at 2022-08-19 00:35:41 UTC
Topic: Netro App
27
Updated at 2022-08-19 00:34:04 UTC
Topic: Netro App
Sync warning even when online
27
Updated at 2022-08-16 19:08:38 UTC
Topic: Netro App
27
Updated at 2022-08-11 20:18:04 UTC
Topic: Netro App
Day view
27
Updated at 2022-07-12 04:10:37 UTC
Topic: Netro App
27
Updated at 2022-07-10 11:25:02 UTC
Topic: Netro App
27
Updated at 2022-07-02 17:31:23 UTC
Topic: Netro App
27
Updated at 2022-06-19 18:52:23 UTC
Topic: Netro App
